Thread: battery condition
Results 1 to 9 of 9
  1. battery condition
    May 2008
    hi hope someone can give me some advice.if i leave the car for a day when i turn on the ignition it will be showing just under 12 volt,once started it will be just above 14 volts,if i stop the engine and turn the ignition on maybe 1 hour later it will show above 12 volt,but if left for 1 day it will be just below 12 volts.is this a sign the battery is on its way out or just me worrying about nothing,cheers,
  2. Re: battery condition
    Unless you have a drainage problem the battery may be getting old. How old is it ?? Regards Peter
  3. Re: battery condition
    May 2008
    Quote Originally Posted by Peter D View Post
    hi have only had the car 6 weeks so i do not know how old the battery is,also after having the car 2 weeks i went to start it and the battery was down to 8 volts after 5 hours on charge was ok and the volts show as first explained.cheers.
  4. Re: battery condition
    And what year is the car and what mileage. Go for a decent run and drive straigt to a ca raccessory shop and ask them to test the batter. They tend to use a pulse discharge system which identifies the internal resistance and the Amp/H capacity and will indicate if the battery is folding. Regards Peter
  5. Re: battery condition
    May 2008
    it is an 02 with 62000 miles cheers for the advice waggy.
  6. Re: battery condition
    That would be the original battery, probably on it's way out. Go and get it tested they do not charge you and takes 10 seconds. Regards Peter
  7. Re: battery condition
    May 2007
    I just had to change the battery on my '99 A6. My symptoms were just the same as yours, but it came on overnight. Car wouldn't start one morning (reading 8V), jumped it, drove to work. When I left the car the charge (non-running) was about 12.5 V, went back at lunchtime to check, and it was reading 8.5 V. Still started though.
    Went straight to Costco and bought a new one. Had to change it then and there as well, because although the car was reading 12V + when I went into the shop, it only read 8V when I came out.
    Be ready for a £80 quid bill.
  8. Re: battery condition
    Aug 2007
    Hook Hampshire
    21 Post(s)
    See elsawin instructions below. If you disconnect the battery, Charge it, wait 2 hours, and take a voltage reading. If less that 12.5v then battery is suspect.
    Regards
    Description of work
    Battery: Check "no load" voltage
    Test units required
    ◆ Digital multimeter V.A.G 1715
    or
    ◆ Hand-held multimeter V.A.G 1526 B
    Notes:
    ◆ The vehicle must not be driven or started with the battery that is to be tested for at least 2 hours before performing measurement.
    ◆ The battery must not be loaded by connected power consumers for at least 2 hours before performing measurement.
    ◆ The battery must not be charged for at least 2 hours before performing measurement.
    ‒ Check voltage between battery terminals with the ignition switched off.
    If the measuring instrument indicates 12.5 V or more, then the battery is OK.
    If the voltage is less than 12.5 V, locate the source of the problem (repair measure).
    Audi A7 3.0TDi 2011 160k miles, engine code CLAB 204bhp 2WD
  9. Re: battery condition
    Nov 2006
    Southampton
    Quote Originally Posted by waggy View Post
    Waggy:
    You need to get a load test (sometimes referred to as a volt drop test) carried out on your battery as terminal voltage is not a reliable method by which the condition of a battery can be determined.
    The real test is to place the battery under load and then see how the voltage behaves.
    Any decent electrical car place should be able to do this for you,
    They disconnect the battery and subject it to a controlled test by which a large current is drawn from the battery and the terminal voltage is monitored under these load conditions.
    If a cell is faulty or there are any problems the terminal voltage will drop off very quickly, a healthy battery will be able to maintain it's terminal voltage even with a high current being drawn from it.
    Hope this helps
    Gazza57
  1. Condition of rear brake discs
    By tommyweaves in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 01-06-2008, 11:09 PM
  2. battery
    By jambo7 in forum Golf MK4 - 1999 - 2004
    Last Post: 21-05-2008, 12:33 AM
  3. Audi a6 cream fabric interior, seats + rear bench verry good condition
    By adamss24 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 23-03-2008, 09:17 PM
  4. How do you get the battery out?!
    By hopperstu in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-01-2008, 06:40 PM
  5. 1.8 T battery
    By johnready in forum Passat - Archive Topics
    Last Post: 07-11-2006, 02:08 PM
