Thread: Engine help with new transponder key
  1. Engine help with new transponder key
    May 2008
    New on here hopefully someone can help. My girlfriend has a new shape Beetle 2000 model. It came with one 3 button key in terrible condition. I bought a new one from Ebay. Bought top half with blank blade and bottom half with matching code to make one new key. I had the blade laser cut to obviously match existing blade. I then coded the key and it will lock and unlock the central locking on the vehicle. However, when the vehicle is started the engine will start and run but will then cut out. Can anyone tell me how to code the key to start correctly without having to go to a VW dealer?
  2. Re: Engine help with new transponder key
    Apr 2007
    Lancashire
    The transponder chip hidden in the top part of the key is most likely still 'immo2'.
    An auto-locksmith will sort it for you, or if you have suitable hardware/software to extract the immo pin, you can add it yourself.
  1. Transponder Required... Apply within ;-)
    By xorkid in forum Polo - Derby - Lupo - Fox
    Last Post: 10-04-2008, 11:22 PM
  2. How to remove Ignition Transponder
    By irfanali_1 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 01-03-2008, 11:45 PM
  3. Ignition Transponder
    Last Post: 12-02-2008, 03:02 PM
  4. Flip key remote/transponder
    By joehepworth in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-01-2008, 10:04 PM
  5. 04 Passat Tdi Key/transponder
    By paulp in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-07-2007, 11:49 AM
