Thread: how do you reset airbag light?
Results 1 to 9 of 9
  1. how do you reset airbag light?
    hi, just had leather fitted to my a6 1.8T. the airbag light stays on whilst driving, is there anyway that i can switch this off?
  2. Re: how do you reset airbag light?
    7 Post(s)
    There will be a fault code logged.
    To clear it and put the light out you need to clear the fault code.
    Look in the vagcom subforum for info.
  3. Re: how do you reset airbag light?
    Take it back. If you have had all the seats done then they may have left a bag disconnect or they turned the ignition on when a seat/bag was disconnected and that set the fault. Regards Peter
  4. Re: how do you reset airbag light?
    Aug 2007
    Wicklow
    Mine's started coming on intermittently. Any ideas?
  5. Re: how do you reset airbag light?
    Quote Originally Posted by Padwick View Post
    Mine was doing that for a couple of weeks and was beginning to annoy me then someone moved the passenger seat and it hasnt appeared since.
    i guess there is a loose connection or a problem with the wiring under the passenger seat but i havent looked at it just happy the light went out.
  6. Re: how do you reset airbag light?
    Well check the wiring. Don't ignore it. Regards Peter
  7. Re: how do you reset airbag light?
    Aug 2007
    Wicklow
    Quote Originally Posted by Peter D View Post
    Not sure if it's the same for all A6's of the same era but you can't get under the seats in mine to check anything. They're right to the floor.
  8. Re: how do you reset airbag light?
    From the back. Regards Peter
  9. Re: how do you reset airbag light?
    Aug 2007
    Wicklow
    Cheers, I'll have a look. Do I need to rip up carpet or anything?
    The airbag plug scares the hell out of me though. I'd end up starting the car while standing outside it for a month after unplugging.
  1. Can I reset airbag warning light
    By Jack 944 in forum New Member Introductions
    Last Post: 10-09-2017, 07:35 AM
  2. 1996 a4 airbag light reset
    By pogues in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 23-08-2008, 05:46 PM
  3. Airbag light reset?
    By VtecJunkie in forum Audi A4 - Archive Topics
    Last Post: 01-02-2008, 12:12 AM
  4. A6 airbag ECU reset
    By gale007 in forum Chat - Anything with wheels
    Last Post: 14-09-2007, 11:56 AM
  5. VAG-COM help needed - airbag light reset
    By maxx in forum Chat - Completely Off Topic
    Last Post: 30-01-2007, 10:55 PM
