Thread: ignition switch
Results 1 to 10 of 15
  1. ignition switch
    May 2008
    hi all,
    im having this problem with my 1995 golf cl tdi,
    i cant get any power to the starter soleniod when i turn the key in the ignition switch.
    i think the switch is knackered,as i can get power if i remove the connector of the switch & link from the "large red cable"to the solenoid cable which is the red/black one.
    should i change the ignition switch or install a "starter button"in the dash?
    any pointers would be helpful
    cheers
  2. Re: ignition switch
    1840 Post(s)
    Of course you should fit a new switch but don’t fit a pattern one, they are useless. By one from a VW dealer only.
  3. Re: ignition switch
    May 2008
    thanks crasher,i bet your waiting for this?
    ive removed the blind screw on left hand side of steering column,but how to remove ignition switch completly?
    cheers
  4. Re: ignition switch
    1840 Post(s)
    You have to remove the column lock unit, the correct way to do this is to remove the collar but that requires an extractor, some people remove the column from the car.
  5. Re: ignition switch
    yeah i had to borrow a decent puller cos the flange you have to pull against is tiny, one of those cheep 3 pronged ones would'ent do it ,the puller needs to clamp around the steering collum as well as pull and you will want a new blind screw so you can get it nice and tight. not too bad a job though
  6. Re: ignition switch
    May 2008
    thanks for replys,
    it looks like i will be fitting a "starter switch"in the dash!!
    which cable is the switched ignition supply so as to feed the new switch,as i think the large red cable is live always?
  7. Re: ignition switch
    1840 Post(s)
    Do you mean the feed to the starter solenoid (red/black) or the ignition live (black)? Why am I helping you dodge it? When the next circuit fails, are you going to have a separate switch for that as well? It will look like the cockpit of a WWII fighter before you know here you are!
  8. Re: ignition switch
    May 2008
    well i managed to remove the ignition switch!!!
    first disconnect the steering column uv joint in footwell,and then removed all electrical plugs around steering wheel.then with the steering wheel locked i removed the blind bolt holding the assembly to the column.then it all came straight out.removed the very small phillips screw holding the switch in.
    now to get a new one!
  9. Re: ignition switch
    May 2008
    update
    just fitted new ignition switch,but now the air bag warning light is staying on.
    had the battery out and on charge before fitting switch.
    any pointers?
    cheers
  10. Re: ignition switch
    1840 Post(s)
    It has logged a low battery (terminal 30) fault code and should clear with a fault code read and clear.
  1. ignition contact switch
    By lpg boy in forum Early Passat Forum - Pre 97
    Last Post: 20-07-2008, 10:54 PM
  2. Audi 80 Ignition switch
    By zkav8or in forum 80 - 90
    Last Post: 22-02-2008, 05:26 PM
  3. Dreaded ignition switch
    By joebrown9 in forum Golf MK3 - 1993 - 1999
    Last Post: 23-01-2008, 09:55 PM
  4. Ignition Switch does not engage Starter
    By massauto in forum Golf MK3 - 1993 - 1999
    Last Post: 21-10-2007, 09:36 AM
  5. MK3 Ignition Switch trouble?
    By milescook in forum Golf MK3 - 1993 - 1999
    Last Post: 24-08-2007, 04:18 PM
