Thread: VAGCOM Fault code
  1. VAGCOM Fault code
    Dec 2006
    Can anybody help me with this one, my car ticks over eratically and stalls at junctions as the revs drop right down.
    VAG COM brings up this fault.
    00282 - Throttle Position Actuator (V60) 36-00 - Open Circuit
    1998 1.6 CL GOLF
    Dec 2006
    ENGINE DOESN'T START
    AFFECTED MODELS: Engine code AHL 1.6 l Simos
    FAULT: Engine doesn't start, stalls when accelerating - fault code 00516, 00625, 00282, 00537 or 00635 in the
    fault memory.
    CAUSE: Analog-digital converter in the ECU stops, causing all sensor values to freeze (e.g. throttle valve
    potentiometer voltage remains the same at closed and open throttle valve).
    SOLUTION: Note: Modified control units have only been designed to cover the damage caused. The latest data
    version includes, of course, all the previous service solutions. For a failure of the analog-digital converter the control
    unit - Part No. 3B0 907 557 D - with data version D01 or with the latest data version D02 can be fitted.
    i will do more diggung to find further info for you..
    RiCKT
  3. Throttle position actuator
    Dec 2006
    Having bought a VW DVD off ebay the only matching description is the 'throttle valve control part' which looks like it is part of the throttle body.
    Is this the same as throttle position actuator?
    Should I replace the throttle body?
    1998 1.6 CL GOLF
  1. Fault code
    By philglasgow in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-04-2007, 08:41 PM
  2. Air Con Condenser fault? VAGCOM detectable?
    By TDi_B5 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-04-2007, 08:38 PM
  3. Fault code reader
    By paddymm in forum Audi A4 - Archive Topics
    Last Post: 02-04-2007, 10:31 AM
  4. fault code reset?
    By JELLYBEAN in forum Archive posts
    Last Post: 07-02-2007, 11:30 PM
  5. MK 3 Gti 16v Fault Code - ABS Problem
    By dravidham in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 16-01-2007, 08:10 PM
