Thread: New Flywheel, Dodgy Dealer?
  1. New Flywheel, Dodgy Dealer?
    May 2008
    Hello, I have just had to have my Flywheel replaced after 28k, thank fully it is still in warranty, it is for a 2.0 TDI, has anyone else had the same? Is it normal for one to go so new?
    Also the dealer recommended that it might be worth my while replacing the clutch! Is he after a quick buck or is it something worth considering?
  2. Re: New Flywheel, Dodgy Dealer?
    May 2008
    Hi
    I also have a 2.0 TDI (05 plate) which was the subject of a recall in regards to the flywheel. This fault effected Tourans, Golfs and Golf Plus', with 2.0 TDI and 6 speed manual gearboxs.
    I got a letter in May 2006, asking me to book the car into a VW dealer to be checked. Luckily mine didn't need replacing.
    The twin-mass flywheel can get damaged because of a not optimally designed through-flow restrictor in the clutch pressure pipe. This can lead to a total failure of the twin-mass flywheel and under unfavourable circumstances to a vehicle fire.
    If they've replaced your flywheel under warranty because of this known fault, then I think the clutch should also be replaced under warranty.
    Maybe give VW UK a ring?
    Katherine
  3. Re: New Flywheel, Dodgy Dealer?
    May 2008
    That's great, mine is a 55 plate I'm not sure if it was ever brought in by another owner, i will check, i'm slightly annoyed by their manner and i'll ask them,
    Would the clutch also be damaged?
  4. Re: New Flywheel, Dodgy Dealer?
    May 2008
    The two are actually connected, so at an educated guess, I would say yes, and I've heard of other people who have had the fault with the flywheel having their clutch changed too at the same time, but to be 100% sure, I'd check with a mechanic first.
    Glad I could be of some help, let me know how it goes.
    Katherine
  5. Re: New Flywheel, Dodgy Dealer?
    Oct 2007
    Quote Originally Posted by Katherine30 View Post
    Hi
    Katherine
    Howd you get that info Katherine!? Good info, and almost right The 2.0 TDI flywheels were recalled purely because of the fire issue..... because of being made from magnesium..... which gcse chemitry shows is slightly combustable!
    I doubt the dealer will replace the clutch. It wouldnt be damaged by the reason this product was recalled. Yet if youve got 100k+ on the car (?) youd be well advised to replace the clutch while theyre at it as it wouldnt have much life left.
    2019 Urus, 2020 RS7
    2014 RS6, 2018 RS5, 2016 RS3, 2019 RS3
    2011 RS5, 2008 S5 V8
    2007 A4 2.0, 2008 Passat 2.0 TDI
    2005 Bora 1.9 TDI, 2000 Bora 1.6 , 1989 Polo 1.4
  1. Help On Buying Gt Tdi!! Is It Dodgy Or Not?
    By PAT_GT_TDI in forum Golf MK4 - 1999 - 2004
    Last Post: 02-04-2008, 10:02 PM
  2. Dodgy turbo?
    By xtreme in forum Bora - 1998 - 2005
    Last Post: 01-02-2008, 09:27 PM
  3. dodgy radio
    By nite in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 30-11-2007, 09:12 AM
  4. Dodgy indicators....
    By gsxr-jon in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 28-11-2007, 10:08 AM
  5. Dodgy indicators...help please...!!!
    By gsxr-jon in forum Archive posts
    Last Post: 27-11-2007, 12:35 PM
