Welcome to the VW AUDI Forum - VWAF.
Results 1 to 10 of 13
  1. #1
    0
    05 Audi A4 2.0 TDI problems
    Hello people
    I have spent most of the day sorting out an Audi A4 that has been repaired after having 10K´s worth of front end damage.
    more or less a complete front end, ALL air bags and dash have been replaced.
    After deleting all the codes to find out what was left i have managed to sort almost ALL of them out but have a few that still remain
    in this list you can ignore the AIR-CON faults as it still needs to be gassed.
    Friday,09,May,2008,13:43:50
    VAG-COM Version: Release 607.3-UD
    Chassis Type: 8E - Audi A4 B6/B7
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
    69 75 76 77
    VIN Number: WAUZZZ8E76A041260
    Address 01: Engine
    Part No SW: 03G 906 016 GN HW: 028 101 211 3
    Component: R4 2,0L EDC G000SG 9618
    Coding: 0000072
    Shop #: WSC 00414
    No fault code found.
    Readiness: 0 0 0 0 1
    Address 03: ABS Brakes
    Part No SW: 8E0 910 517 D HW: 8E0 614 517 AK
    Component: ESP8 front H04 0120
    Coding: 0004401
    Shop #: WSC 00654
    3 Faults Found:
    01321 - Control Module for Airbags (J234)
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 1
    Fault Frequency: 6
    Reset counter: 40
    Time Indication: 0
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x0722
    Hex Value: 0x0014
    Hex Value: 0x209C
    Hex Value: 0x0001
    18055 - Check Coding of ECUs on Powertrain Data Bus
    P1647 - 000 - -
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 6
    Reset counter: 40
    Time Indication: 0
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x0722
    Hex Value: 0x0014
    Hex Value: 0x139C
    Hex Value: 0x0001
    01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
    000 - -
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 6
    Reset counter: 40
    Time Indication: 0
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x0722
    Hex Value: 0x0024
    Hex Value: 0x019C
    Hex Value: 0x0001
    Address 08: Auto HVAC
    Part No: 8E0 820 043 AJ
    Component: A4 Klimaautomat 2831
    Coding: 00000
    Shop #: WSC 00000
    2 Faults Found:
    00819 - High Pressure Sensor (G65)
    07-00 - Signal too Low
    01206 - Signal for Duration of Ignition Off Time
    27-00 - Implausible Signal
    Address 09: Cent. Elect.
    Part No: 8E0 907 279 L
    Component: int. Lastmodul ECE 0504
    Coding: 10001
    Shop #: WSC 06325
    2 Faults Found:
    01496 - Bulb for Fog-Lamps; Left (L22)
    30-00 - Open or Short to Plus
    01500 - Bulb for Fog-Lamps; Right (L23)
    Address 15: Airbags
    Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
    Component: Airbag 9.41 H14 4230
    Coding: 0033622
    Shop #: WSC 00000
    Address 16: Steering wheel
    Part No: 8E0 953 549 Q
    Component: Lenksáulenmodul 0601
    Coding: 04042
    Shop #: WSC 06325
    Address 17: Instruments
    Part No SW: 8E0 920 951 E HW: 8E0 920 951 E
    Component: KOMBI+WFS 4 H12 0110
    Coding: 0006441
    Shop #: WSC 00426
    Address 45: Inter. Monitor
    Part No: 8E0 951 177
    Component: Innenraumueberw. 0804
    Coding: 00001
    Shop #: WSC 00000
    Address 46: Central Conv.
    Part No: 8E0 959 433 CA
    Component: Komfortgerát T3B 3332
    Coding: 07167
    Shop #: WSC 06325
    Part No: 8E2959802F
    Component: Tőrsteuer.FS BRM 0406
    Part No: 8E2959801B
    Component: Tőrsteuer.BF BRM 0205
    Part No: 8E0959801A
    Component: Tőrsteuer.HL BRM 0205
    Part No: 8E0959802A
    Component: Tőrsteuer.HR BRM 0205
    1 Fault Found:
    00958 - Key 4
    35-10 - - - Intermittent
    Address 56: Radio
    Part No: 8E0 035 186 D
    Component: concert II GRO 0004
    Coding: 01065
    Shop #: WSC 06325
    Address 76: Park Assist
    Part No SW: 8E0 919 283 B HW: 8E0 919 283 B
    Component: Parkhilfe 4-Kan H06 0020
    Coding: 0000014
    Shop #: WSC 06325
    Address 77: Telephone
    Part No SW: 8P0 862 335 C HW: 8P0 862 335 C
    Component: FSE_255x BT H18 0160
    Coding: 0001622
    Shop #: WSC 06325
    End -------------------------------------------------------------------------------------------------
    Can ANYONE help as i have double checked the slip ring that is also NEW and it seems to be fully aligned
    the other one is the KEY fault that seems to keep popping it´s head up
    ANY clues PLEASE gent´s
    Andy
  2. #2
    May 2007
    knee deep in clunge
    458
    Re: 05 Audi A4 2.0 TDI problems
    adapt the abs in airbag Channel 051: ESP-Data (Brake)
    02 = Front: C54 / Rear: C38 (PR-1LZ+1KD)
    04 = Front: FN3 15" / Rear: C38 (PR-1LB/1LE+1KD)
    06 = Front: FN3 16" / Rear: C38 (PR-1LT/1LF+1KP)
    12 = Front: FNR G60 16" / Rear: CII 41 (PR-1LA/1LC/1LD-1KW)
    14 = Front: FNR G60 17" / Rear: CII 43 (PR-1LJ+1KE)
    20 = Front: Brembo M6 19" / Rear: CII 43 (PR-1LU+1KY)
    22 = Front: Brembo M8 18" / Rear: CII 43 (PR-1LP+1KY or PR-1LV+2EG)with the correct data from the pr numbers on the data sticker then you can reset steering angle and clear down the faults.
    [Select]
    [03 - ABS Brakes]
    [Fault Codes - 02]
    [Done, Go Back]
    Start Engine (session still running).
    Turn steering wheel at least 30 ° left and back straight ahead.
    [Meas. Blocks - 08]
    Group 005 Field 1 (Steering Angle Sensor -G85-)
    Specification: 0.0 °
    Tolerance (when straight): ±5.0 °
    [Done, Go Back]
    [Security Access - 16]
    Enter 40168
    [Do It!]
    [Basic Settings - 04]
    Group 001
    [Go!]
    [Done, Go Back]
    [Fault Codes - 02]
    All fault codes should have disappeared.
    [Done, Go Back]
    [Close Controller, Go Back - 06] as for the key fault 00958 - Key 4: Adaptation Limit Surpassed
    Possible Symptoms
    Remote control not working.
    Possible Causes
    Key not matched.
    Key operated more than 200 times while out of range so you need to configure the code for air bag so the powertrain message is correct.
  3. #3
    0
    That is FANTASTIC !!!!!
    Will give it go on Monday and post up how it went on
    i bloody know it was the the above for the angle sensor but could not remember how i did it last time on my Golf LOL
    as for the key NOW reading that i cant remember the key working off the fob to open or close it
    so could be the battery in the fob is dead
    Thanks again for the help
    Andy
  4. #4
    Magdeburg, Germany
    http://wiki.ross-tech.com/index.php/18055/P1647/005703
    http://wiki.ross-tech.com/index.php/01321
    P.S.: You should update to a current version of VAG-COM, updates are free as you should know...
    Sebastian @ www.Ross-Tech.com
  5. #5
    0
    Thanks for the info as had another go at it today
    so far i have the key sorted and also the angle sensor but STILL have the following causing me some trouble lol
    i have been through the above links and followed the procedures but this is stopping me i think
    Enter 30475, to enable the basic setting.
    If you are having problems performing this security access, contact us.
    When i enter the code 30475 all i get is a message that it is blocked by SEED
    cant remember the full message lol
    just for information
    the car had a FULL set of front air bags, sensors, seat belt pre pensioners and also a NEW air bag ECU.
    i have recoded the new ECU with the soft coding and air bag lights have gone out
    The car also had a NEW air bag slip ring
    also the lights i have on the dash are
    ABS light
    Traction control light and hand brake light
    these faults STILL remain
    000 - -
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 6
    Reset counter: 40
    Time Indication: 0
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x0722
    Hex Value: 0x0014
    Hex Value: 0x209C
    Hex Value: 0x0001
    P1647 - 000 - -
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 6
    Reset counter: 40
    Time Indication: 0
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x0722
    Hex Value: 0x0014
    Hex Value: 0x139C
    Hex Value: 0x0001
    Any more clues please chaps ?
    PS will up date ASAP my VAG-COM
    Andy
  6. #6
    Magdeburg, Germany
    Feel free top contact me directly for assistance, but make sure to include a scan with at least version 704 or even better the latest Beta 804 as well as your name/address/license number so we can find you in our customer database...
  7. #7
    May 2007
    knee deep in clunge
    458
    the air bag control unit code wrong or its the wrong part number,check the last letter of the old control unit part number,if its differant check it superseeded to the new one and take it to audi to configure the code from th pr numbers.abs,airbag and engine electrics are on the powertrain bus network and need coding to pr number specification
  8. #8
    Magdeburg, Germany
    Part number is fine as well as the coding.
  9. #9
    0
    I checked the PN before it was fitted is is identical to the old one
    i am quite new to VAG-COM in genral terms and can do most of the basic stuff and although this has phased me a little i think i did quite well lol
    from about 30-40 faults i thought it was going well untill this came up
    Think i will get it over to Audi to finish the job then all i need to do is get the customer to bring ALL the other keys to code them as i think they will not work now as i have set it to just 1 as it is the only key i had today
    Thanks guys
    and safe to say this one beat me this time lol
    oh well onwards and all that
    Andy
    yummm BETA version, will pop over and have a gander
  10. #10
    May 2007
    knee deep in clunge
    458
    see you soon dent reform,vag com is fine but 5051b guided has all the info for this i have 704 vag comand beta 803 plus use of 5051/5051b 5052 and 5053 plus elsa pro and my nogggin and Sebastian is a good man also with a wealth of vagcom knowledge.If you have et adaption channel 50 and 51 then it should be ok as you dont need to perform the security access for j706 but abs control unit needs recoding for new airbag control unit
  1. Audi A4 Help I've Got Problems
    By mickyboy10001 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 21-09-2009, 04:12 PM
  2. audi a4 1.8 more problems plz help
    By cookie boy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-04-2008, 06:51 PM
  3. 2 problems! Audi A6 1.8T PLEASE HELP!
    By eyece in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 22-03-2008, 08:49 PM
  4. Audi 80 2.0 ABS problems...
    By richardahope in forum 80 - 90
    Last Post: 21-12-2007, 08:01 PM
  5. Audi A4 problems
    By Doug in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-07-2007, 01:15 PM
Back to top
Disclaimer: VW Audi Forum is an "independant enthusiast website", and is in no way related to any of the Worldwide Volkswagen,Audi,Seat,Skoda,Bentley,Bugatti,or Lamborghini group of Companies. For official upto date information on any of there vehicles, please visit the official websites. Any comments made throughout this website, are the views of the respective poster, and in no way represent the views of the VW Audi Forum Administration, or the worldwide Volkswagen & Audi Group of companies.
Copyright: Images used on this website by the Administration are "Copyright" of Volkswagen GB, Volkswagen AG (Germany), Audi GB, Audi AG (Germany), Volkswagen Motorsport GB, Volkswagen Motorsport AG (Germany), Audi Motorsport AG (Germany), Volkswagen Racing GB, Bentley, Bugatti, and Lamborghini. No image can be replicated by anyone WITHOUT the relevent Companies written permission.
Copyright: VW Audi Forum is an AUTHORISED DEALER for the Surf City Garage range of car care products. All Surf City Garage images are "Copyright" of Surf City Garage
Page copy protected against web site content infringement by Copyscape
- VW AUDI Forum - The No1 VW Audi Forum - Volkswagen (VW) - Audi - Seat - Skoda - Bentley - Bugatti - Lamborghini - Porsche - VW Audi Forum -
- www.vwaudiforum.co.uk - www.vwaf.co.uk - www.vwaf.co.uk - www.vwaudiforum.co.uk -
/p
