Thread: Audi 80 Fans not spinning
  1. Audi 80 Fans not spinning
    Aug 2006
    As the subject suggests the engine fans on my Audi seems to have stopped spinning, this is causing the radiator water to go very quickly. Anyone got any ideas on where to start looking to get them spinning as they should. BTW they do go round still if i move them.
    Than ks for your help
  2. Re: Audi 80 Fans not spinning
    Feb 2007
    Easy dude...use some ole cables to test your fan by directly hooking it up to the battery-terminals.
    If it works (spins) the change the sensor with two cables, located on the top of the hose running into the engine-block (located on the driverside of your engine) and all should be OK.
  1. Hi All Audi fans
    By Ash333 in forum New Member Introductions
    Last Post: 22-03-2008, 11:33 PM
  2. Audi Tt Radiator Fans
    By estartit in forum TT - 8N Forum - 1998 - 2006
    Last Post: 24-11-2007, 12:45 PM
  3. G'day Audi fans
    By gungho in forum New Member Introductions
    Last Post: 10-07-2007, 08:08 PM
  4. Audi Coupe rad fans & temp gauge
    By john493 in forum Archive posts
    Last Post: 13-11-2006, 01:49 PM
