Thread: Egr Valve - Low Flow, 1.4 Petrol
Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
  1. Re: Egr Valve - Low Flow, 1.4 Petrol
    #21
    1840 Post(s)
    Positive Crankcase Ventilation
  2. Re: Egr Valve - Low Flow, 1.4 Petrol
    #22
    Oct 2009
    Halesowen, UK
    Thanks Crasher, I guess the pcv pipe is on the left hand side looking at the car and is the large pipe, that pushes onto the rear left hand side.
    this pipe is clear, and no oil in air filter, I did service recently, and replaced the air filter which was very black, but it was just dirt, like it hadnt being changed for 5 years (which funnily enough is how long the previous owner had had the car)
    taking car into indie on friday.
    if its an electric egr, how do they test it?
  3. Re: Egr Valve - Low Flow, 1.4 Petrol
    #23
    1840 Post(s)
    The EGR valve is tested using a diagnostic computer in Basic Settings 04 Main Group 075 observing Display Zone 4 whilst applying WOT briefly and then letting the engine run down where the text in Display Zone 4 will change from “Test off” to “Test on” and then either “Sys OK or “system not OK”.
  4. Re: Egr Valve - Low Flow, 1.4 Petrol
    #24
    Oct 2009
    Halesowen, UK
    I took car into an indie, vw/audi, they charged me Ł30 and said its the egr valve. I cant get the engine management light to go off after I change the egr valve, so have to take it back and let them do what you said crasher.
    but what to do? get a new one or a 2nd hand one?
    the garage gave me a number for a 2nd hand stockist, but whats the point of putting a 2nd hand one in when that could knacker up again in a month?
    do you know best cheapest place to get one from?
    and on the car its part # 036131503 M
    but they are telling me to get 036131503 T
    why is that ?
    Last edited by tiredeyes69; 30-10-2009 at 12:30 PM. Reason: wanted to add more info
  5. Re: Egr Valve - Low Flow, 1.4 Petrol
    #25
    1840 Post(s)
    036 131 503 M is correct for a 2001 Golf 4 with an AXP engine.
    036 131 503 T is for later cats with BAC and BCB engines.
    Buy a new EGR valve from someone like GSF.
  6. Re: Egr Valve - Low Flow, 1.4 Petrol
    #26
    Oct 2009
    Halesowen, UK
    I rang VW Redditch, they have 1 (T) and the gaskets in stock. Ł150 for egr, and Ł80 + vat for fitting. I got them down to Ł200 all in, as I said it takes 15mins to swap egr valve and 15 mins to do the computer bit and test drive. fair play, they got me in after 1 hour, they spent 1 hour on car and gave it a good look over for free. nowt else wrong apart from tyres. the parts and labour come with 2 years guarantee, so if it buggers up again at least I have made init :-)
    Thanks for all your help Crasher, appriciate it.
    Oh and the car drives supurb, it has a slight hesitation at 1800 - 2000 revs in 3rd gear only, but pulls great in 5th at 40mph.
    and im still saving the eviroment a little. its geting 100 miles to a Ł10 so far.
    Im hoping for an improvement now new egr valve in.
  7. Re: Egr Valve - Low Flow, 1.4 Petrol
    #27
    london
    Quote Originally Posted by tiredeyes69 View Post
    Whats the pcv pipe ?
    I assume it's a positive crankcase ventilation pipe.
  1. Why cant i get the fuel to flow??!!?!?!
    By Adam_W in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-02-2008, 05:12 PM
  2. Petrol 2 Stroke Mix in Petrol Engine
    By gcmozart in forum Chat - Anything with wheels
    Last Post: 17-11-2007, 11:13 PM
  3. Air Flow meter
    By carlo in forum Early Passat Forum - Pre 97
    Last Post: 10-11-2007, 09:04 AM
  4. mass air flow or not??
    By phil dean in forum Passat - Archive Topics
    Last Post: 26-07-2007, 09:40 AM
  5. EGR Valve flow too slow - 1.4 16V Leon 2001
    By Muttley60000 in forum Leon
    Last Post: 25-06-2007, 10:49 PM
