Thread: audi concert stereo problems.
  1. audi concert stereo problems.
    perth
    the standard tape stereo in my 2000 a4 is playing up.i have the standard 6cd changer in the boot but the mode button to go onto a cd nothing happens.the same when i have a tape in and press mode to go back onto radio nothing happens so the mode button dont work at all.is this common?it seems that the volume can go funny but everything is fine on mine other than the mode button not working.
  2. Re: audi concert stereo problems.
    Jun 2008
    Hello i have a similar problem in my 2001 A6 everything works fine while the ignition is off and the key in the barrel. But when i turn on the ignition the volume goes through the roof and none of the buttons on the head unit work at all. Turn the key off again and the volume stops rising and all the buttons work......very frustrating!!
    Did you ever work out what the problem was, or how to fix it???
    Regards Bish
  3. Re: audi concert stereo problems.
    Mar 2008
    Bradford, West Yorkshire.
    EEPROM failures cause numerous faults on these units and are very common.
    Not easy to replace unless you're competent with SMD's.
    But what do I know. I have no 'rep power'.
    Registered VCDS (VagCom) owner. v812xx Hex&CAN.
    Bora Highline 130pd ST3'd (Fast Road map) to 170bhp & 300lbft (ish!)
  4. Re: audi concert stereo problems.
    Dec 2006
    Wiltshire
    See the thread link in my signature - All the info is there.
    A6 (2007)TDi SE Avant
    Gone but not forgotten - A4 2.5TDi Avant, Imola Yellow S3 , Golf VR6 Highline
  5. Re: audi concert stereo problems.
    Mar 2010
    London UK
    First time posting...
    Have an Audi A4 2001 model 1.9 TDi. CD / radio player has sudelnly malfunctioned. All buttons on the right of the console work eg TP, Mode etc. However on the left side the CD eject button doesnt work, same applies for FM and CD buttons.
    On top of this CD functions sometimes work, and the radio stations hop around.
    The unit does play some kind of music some of the time, but not to the standard I need.
    Any ideas, can I fix it for cheap, shall I talk to Audi, or buy another unit on Ebay?
    thanks all!
  6. Re: audi concert stereo problems.
    Jan 2015
    Borehamwood
    Hello everyone,
    I was wondering if the problem was solved?
    I'm having the same issue with the mode button not working and cant seem to figure out why
  7. Re: audi concert stereo problems.
    Sep 2018
    Idaho, USA
    Greetings, I have a 2005 Audi A4 quattro and my CD player stopped ejecting CD's, my 2005 A4 Avant also developed the same problem. Both units had 6 CD's that would not eject. The problem on both symphony stereos is this: The eject system is driven by a small gear that is activated when you eject the CD's. Both stereos have this gear broken. I can fix them, but I haven't found a source for the small gears. I'm tempted to make my own out of brass and end this problem until the stereos fry. Q. would anyone know of a source for the gear or gear kit? It would take some time to make the gears and I want to avoid it if I can purchase the kit.
    Please reply and let me know.
    Cheers.
  1. Bose concert stereo problems
    By Paul A4 1.8t in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-04-2008, 03:53 PM
  2. Changing Stereo from Audi Concert...
    By webchem in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 01-04-2008, 07:35 PM
  3. audi a4 1.9tdi concert stereo and climate control buttons.
    By shaz75 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 14-02-2008, 11:47 AM
  4. Audi Concert stereo model # question with PIC
    By ianmatho in forum Archive posts
    Last Post: 27-10-2007, 01:56 AM
  5. Audi Concert Volume problems!!
    By bungle in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-08-2007, 10:14 AM
