Thread: Clutch pedal switch -F36, Implausible signal
  1. Question Clutch pedal switch -F36, Implausible signal
    Mar 2008
    Hi, I have this (and only this) fault on my V5 passat(170).
    Would this have any effect on a car that doesnt have Cruise control?
    I have a strange misfire/hesitation/shunt around 2-3k rpm that I am trying to work out.
    Have tried coil on plug, MAF.
  2. Re: Clutch pedal switch -F36, Implausible signal
    I had this problem on my A4, started off with the clutch swith then I had the shunt which caused the EPC light to come on. I ran the Vag com which said i needed a new engine sensor. Got this replaced (only £35 for the part but supposed to be a really fiddly job) and they found a split vacuum hose, the garage said this could have been the cause of all the problems all along- since having it sorted no problems at all and it runs a dream.
  3. Re: Clutch pedal switch -F36, Implausible signal
    1840 Post(s)
    Even without cruise, it needs the clutch pedal switch input. The one on our Golf V6 4M failed and caused driveline shunt when changing gear.
  4. Cool Re: Clutch pedal switch -F36, Implausible signal
    Mar 2008
    Well, it seems alot better now.
    The car has full VW SH , it had a new MAF last june ,but also had a new brake master cylinder and servo last month (VW fitted), so they must have been working around the pedal box.
    Because, tonight I checked the switch and.............................................
    it was unplugged !!!!!!!!
  5. Re: Clutch pedal switch -F36, Implausible signal
    1840 Post(s)
    Muppets!
  1. Clutch pedal Help please
    By Gomar in forum Golf MK4 - 1999 - 2004
    Last Post: 17-01-2009, 02:00 PM
  2. clutch pedal
    By frank99jc in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-07-2008, 09:47 AM
  3. CLutch pedal
    By sonic in forum Polo - Derby - Lupo - Fox
    Last Post: 11-03-2008, 08:26 AM
  4. Error Code- Potentiometer for EGR?? Implausible signal ??
    By ardasaliah in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 13-01-2008, 09:57 PM
  5. MAF Implausible Signal
    By idawson in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 19-10-2007, 02:25 PM
