Thread: Polo 1.3 1995 starting problem
Results 1 to 8 of 8
  1. Polo 1.3 1995 starting problem
    Mar 2008
    0
    I have a mark 4 1.3L Polo, but recently there has been a problem when starting.
    It actually strikes up fine, but then immediately stalls after about 2 seconds as there is just a flat spot. The revs go up as usual, but rather than tick over normally it drops to 0 revs and cuts out. (It's similar to cars with manual chokes, when they just cut out straight away).
    After an hour of trying I gave up and called the breakdown company, who couldn't find the problem, they then towed it to the garage and it started up first time?? They checked the engine and can't find any faults. I know this will happen again so am left with a car that's 0% reliable.
    Anybody else encountered these problems?
    Paul.
  2. Re: Polo 1.3 1995 starting problem
    11
    Hi This sounds like the immobilizer have you had a fault code read
  3. Re: Polo 1.3 1995 starting problem
    Mar 2008
    0
    Yeah, I did mention the immobiliser to the garage, but he said he'd run it through the diagnostics and there was no fault. Would it start at all if the problem was the immobiliser? Because it does actually fire up, but then just goes dead.
    It is an after market immobiliser, so I do still question it.
  4. Re: Polo 1.3 1995 starting problem
    11
    Hi an aftermarket immobilizer will not show up on the cars diagnostic system.There will be only one way to find out if it is the immo and that is to remove it.
  5. Re: Polo 1.3 1995 starting problem
    Mar 2008
    0
    Ah right, the guy at the garage didn't know this - he said that the immobiliser hadn't reported any problems. I think I'll just go ahead and remove the immobiliser then as this sounds to be the issue - is it an easy job?
  6. Re: Polo 1.3 1995 starting problem
    Mar 2008
    0
    Quote Originally Posted by redimp View Post
    I also a VW Polo (95) and have the same starting prob you described. A diagnostics came up with a Sensor hall fault (G40) but am not sure this is the problem....
    A friend also mentioned the possibility that it may be the immobiliser, so I would like to ask if you DID remove it and if it solved the problem?
    And, did you manage to do it yourself or did you have to go to a garage?
    Please let me know.
    Thank you.
  7. Re: Polo 1.3 1995 starting problem
    Mar 2008
    0
    Cunha,
    I got the fault sorted and it was the immobiliser. I spoke to a few people and this seems to be a current fault with the polo. The immobiliser was removed at a cost of 80, and it sorted the issue.
    I was told that if the same thing re-occurs it may be the ignition barrel that needs replacing at a cost of about 150. I'd recommend getting a fault reading done.
    Paul.
  8. Re: Polo 1.3 1995 starting problem
    Mar 2008
    0
    Hi Paul,
    Thank you very much for your quick reply!
    I did have a fault reading done and it came back with:
    Hall Sensor - G40 - 00515
    No signal, permanent fault.
    This was described by someone else in the forum, with a very different problem on his Polo: (consuming too much petrol), which made me question the reliability of the test. More so when I also read, in the response to his question, someone saying that this reading was returned because they did the test with the engine NOT running (exactly what they did in my case!!), so I'm not sure if the sensor is 'the' problem.....
    Also, friends suggested the immobiliser could be the problem, and that's why I wanted to know if it resolved your problem. Before I go and get more money spent, replacing things that are not problematic.
    So, I think I should remove the immobiliser too.
    You never had the same starting prob again since you removed it, right?
    Thank you once again for your reply.
    Kind regards
    Cunha
  1. Polo Starting Problem (intermittent)
    By Edmund in forum Polo - Derby - Lupo - Fox
    Last Post: 18-08-2010, 08:40 AM
  2. Problem Starting Polo
    By roymarsden in forum Polo - Derby - Lupo - Fox
    Last Post: 19-03-2008, 12:32 AM
  3. Starting Problem - 99 Polo - 1.4CL
    By wendyd in forum Polo - Derby - Lupo - Fox
    Last Post: 28-09-2007, 01:38 PM
  4. Another Polo starting problem
    By a4pacific in forum Polo - Derby - Lupo - Fox
    Last Post: 23-09-2007, 10:36 AM
  5. 1995 passat starting problem
    By firefox337 in forum Archive posts
    Last Post: 14-10-2006, 06:43 PM
Disclaimer: VW Audi Forum is an "independant enthusiast website", and is in no way related to any of the Worldwide Volkswagen,Audi,Seat,Skoda,Bentley,Bugatti,Porsche or Lamborghini group of Companies. For official up to date information on any of there vehicles, please visit the official websites. Any comments made throughout this website, are the views of the respective poster, and in no way represent the views of the VW Audi Forum Administration, or the worldwide Volkswagen & Audi Group of companies.
Copyright: Images used on this website by the Administration are "Copyright" of Volkswagen GB, Volkswagen AG (Germany), Audi GB, Audi AG (Germany), Volkswagen Motorsport GB, Volkswagen Motorsport AG (Germany), Audi Motorsport AG (Germany), Volkswagen Racing GB, Bentley, Bugatti, Porsche and Lamborghini. No image can be replicated by anyone WITHOUT the relevent Companies written permission.
Page copy protected against web site content infringement by Copyscape
- VW AUDI Forum - The No1 VW Audi Forum - Volkswagen (VW) - Audi - Seat - Skoda - Bentley - Bugatti - Lamborghini - Porsche - VW Audi Forum -
