Thread: Audi A6 2.0 TDi 2005 'juddering' clutch
  1. Angry Audi A6 2.0 TDi 2005 'juddering' clutch
    Nov 2006
    I have an Audi A6 2.0 TDi (Jan 2005) 17k miles. After about three months of owning it, it developed what I call a 'juddering' clutch. Intermittently, when pulling away in 1st gear, the clutch judders - and no matter how you adjust the revs, or how slowly or quickly you release the clutch, it still happens. I have been driving for 28 years, so I don't think it is me!
    Sometimes it is worse than other times - sometimes it will make the car stall, other times it just makes for a very jerky pull away.
    Also, general gear changes at all speeds seem very jerky - as though the clutch isn't releasing smoothly - sort of 'catching'.
    It is also intermittent - with no obvious pattern as to when it does or doesn't happen.
    The first time it went to the dealers, they said that they had updated the software , which seemed to cure it for about a month, but then it came back. Since then it has been back to the delears twice, and they say they cannot find a problem.
    Is anyone else out there seeing the same problem, or have any ideas?
    Mar 2007
    I had the same with a 53 Reg A4 2.5TDI and the audi gararge replaced the clutch. Now all OK. Only done 15K miles.
    Martyn
  3. Re: Audi A6 2.0 TDi 2005 'juddering' clutch
    DUBAI AND UK
    I Have The Same Problem With My 2005 2.7tdi A6. Now On 3rd Clutch Each One Average 10k Miles.
    I Know It's Not Me As The Last One Had A New Clutch At 140k!
    We Have Audi Specialists From Germany Over To Sort It Out, And Yet Now At 30k Miles The Clutch Has Gone Again. Most Common In Wet Or Damp Conditions, You Get A Judder. Dry Conditions It Is Fine.
  4. Re: Audi A6 2.0 TDi 2005 'juddering' clutch
    Jan 2009
    hi all,
    first post first audi.
    i too have a 2005 se 2.7 tdi manual and the clutch is terrible. like above it judders in first gear but whats worse is when the clutch is dipped it makes a horrible grinding/whining noise. whats the soloution for this???
    not impressed at all had a mercedes before this at the moment wish i had it back!!!!!!! and how much is a new clutch for it?
  1. Audi 80 tdi - juddering problem
    By Ed Ray in forum 80 - 90
    Last Post: 10-12-2015, 11:33 AM
  2. Replies: 128
    Last Post: 11-05-2015, 11:06 AM
  3. 2005 Golf GTI clutch squeal
    By Robibbeson in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 09-05-2007, 09:13 PM
  4. 2005 1.9 TDI 168bhp & slipping clutch
    By studuff in forum Archive posts
    Last Post: 10-01-2007, 09:01 AM
  5. AUDI UK ENDS 2005 ON ITS BEST HIGH TO DATE
    Last Post: 23-12-2005, 09:27 PM
