Thread: Oil Problem Vw Golf Mk4 2.0 Gti
  1. Oil Problem Vw Golf Mk4 2.0 Gti
    hope someone can help me!
    I have a vw golf mk4 golf 2.0 and today i was driving and my oil light came on (orange one). ive checked my oil and have even topped up but the light has not gone offf. The thing is that when i took off the top to add oil, the top had yellow gooey stuff on it. (the inside of it)
    I have never had this problem before so could pls someone advice me on what it could be?
    i need advice before i sort out cos i dnt wanna get ripped of.
  2. Re: Oil Problem Vw Golf Mk4 2.0 Gti
    Apr 2007
    N.Ireland
    Welcome to the forum.
    As far as I remember, if the oil light comes on yellow/orange then it means the oil level is too low and if the light comes on red then it means the oil pressure is too low. If you've checked and you're sure the oil level is correct then I'd be inclined to say the oil level sensor is faulty. I don't think the yellow gooey stuff on the filler cap is too much to worry about especially with the weather being so cold the engine can be prone to condensation mixing with the oil. Get it connected to VAG-COM if you can, this would diagnose if it is a faulty sensor or take it to a garage and get their opinion.
    Golf GTD 2.0 DSG (ACC | Winter Pack | 18" Vancouvers | RCD510 | Parking Sensors, Rear Camera & Park Assist | Cruise Control | Flat Tyre Indicator | Luxury Pack | Rear Airbags)
  3. Re: Oil Problem Vw Golf Mk4 2.0 Gti
    Oct 2009
    stanford-le-hope essex
    Hi as for the yellow stuff on cap i had that on my mk4 2.0 gti the other week my girlfriend only drives a couple of miles each time she uses it. i did a compression test it was good i cleaned the cap and then went on a couple of long drives done about 120 miles since checked the cap this morning its still clean no yellow stuff in sight. Just keep an eye on the temp gauge if it starts getting hotter than normal then get it checked if temp is normal its just condensation in the cap. aaron
  1. Problem with my MK3 Golf HELP
    By MK3_Golf_zak in forum Golf MK3 - 1993 - 1999
    Last Post: 10-12-2007, 12:49 AM
  2. Golf Problem
    By adam snowden in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 25-08-2007, 05:09 PM
  3. Problem with X Reg Golf
    By oomsy in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 31-07-2007, 10:38 AM
  4. Problem with my MK3 Golf GL TDi.
    By Davey_G in forum Chat - Completely Off Topic
    Last Post: 24-01-2007, 09:17 PM
  5. abs problem on a golf 1.8t
    By wilko 1.8t in forum New Member Introductions
    Last Post: 10-10-2006, 10:58 AM
