Thread: how to remove a door panel on Seat Alhambra
Results 1 to 10 of 10
  1. how to remove a door panel on Seat Alhambra
    I want to remove the door panel on a SEAT Alhambra to take a look at the window winder mechanism on one of the rear doors and also the central locking mechanism on the driver's door. Both appear to have failed independently.
    Does anyone know how to remove the inner door panel? I can't see any obvious screws etc.
    Any help greatly appreciated.
    Thanks,
    Tim
  2. Re: how to remove a door panel on Seat Alhambra
    Dec 2007
    is yours an earlier model??
    If it is ... pop out the plastic trim behind the inner door handle and you`ll find a screw in there ... once thats out its just a matter of GENTLY popping the door panel clips off from behind the panel with a trim tool .
  3. Re: how to remove a door panel on Seat Alhambra
    Thanks for the reply...
    It's the newer model...
    Tim
  4. Re: how to remove a door panel on Seat Alhambra
    Mar 2009
    Edinburgh
    Tim
    did you ever attempt to remove the door panel? I have a similar problem with my rear passenger window which is now stuck open. have removed the plastic trim around the handle but no sign of a screw yet!
    needing to turn my attention to this urgently as the weather has been good but is meant to be rainy for the rest of the week!!!
    K
  5. Re: how to remove a door panel on Seat Alhambra
    Mine is a newer model. Part of the handle (what you would use to pull the door shut) clips out. You have to lever it out with your thumbs pushing downwards on it and then the rest of it, electric window switch and all, can be lifted out. This reveals 3 bolts. once these are undone the door panel can be removed. Might require a bit of force. I then understand there is a plastic sheet or something across the door which might need to be removed.
    Another thing to consider is that it might be a wire that has broken. Check the trunking which is visible when you open the door in the gap where the hinges are. It's a black tube through which runs the wires from the central locking and electric windows. These wires are prone to breaking and might simply require a bit of soldering. If the window worked intermittently for a while before packing up completely then this is the most plausible explanation.
    Good luck. Be interested to know how you get on.
  6. Re: how to remove a door panel on Seat Alhambra
    Mar 2009
    Edinburgh
    Whole in one! brown wire completely worn through! atleast I didn't take the door panel off.
    took some photos too which might assist others. I did spend ages trying to pry off the wrong end of the flexi connector, but luckily failed!
  7. Re: how to remove a door panel on Seat Alhambra
    Excellent! Well Done!
  8. Smile Re: how to remove a door panel on Seat Alhambra
    Jun 2010
    london
    Quote Originally Posted by Ktread View Post
    Mate you saved me £560.00 pounds as i was quoted this to fit new door regulator and relay by seat as the picture showed IT WAS THE BROWN WIRE ,it was broken inside the rubber ,going to get a 1 inch crimp connector ( like the 1 you use on speakers ) as trying to solder the wire was to fiddly .
  9. Re: how to remove a door panel on Seat Alhambra
    Jun 2010
    grimsby
    hye i have a 2 ltr t plate alhambra and i have just bought a remote central locking kit i do already have central locking just want to add remote with reciever just wondering if you know any of the wires here in the pic as i need to know them to install or do you know of anywere to get the wiring diagram tryed evrywer to no avail thanks
  10. Re: how to remove a door panel on Seat Alhambra
    Apr 2013
    Warrington, UK
    New to forum, its my father in laws car but just had the same problem. What surprises me is that even with the brown wire broken when you try the up/ down button you can hear the motor turn and try to lower/ raise the window. Because of this I had ruled out a broken connector but as per this post and photos it was the brown wire that was broken.
    Thanks,
    Neil
  1. Seat Alhambra Heater Inoperative
    By Iluvmybus in forum Alhambra
    Last Post: 19-01-2009, 06:36 PM
  2. Any Manuals For Seat Alhambra?
    By Robin Vitiello in forum Alhambra
    Last Post: 02-03-2008, 10:39 PM
  3. seat alhambra gearbox u/s
    By jugs1960 in forum Touran - Sharan - Caravelle
    Last Post: 13-12-2007, 03:32 AM
  4. how to remove a door panel from a mark 4 golf
    By garrygolf1.6 in forum Golf MK4 - 1999 - 2004
    Last Post: 10-11-2007, 06:31 PM
  5. Touran - remove driver door panel
    By rmcleod1576 in forum Touran - Sharan - Caravelle
    Last Post: 27-10-2007, 03:37 PM
