Thread: 00515 Hall Sensor G40 No Signal - HELP
Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
  1. Re: 00515 Hall Sensor G40- HELP
    Dec 2010
    beirut
    hi, i have a mk4 1999 and i have a engine problems the car i consuming a lot of fuel and and my rpm i not stable wen the car is in nutral or park it will go up and bown betwen 1000-1500rpm, and it will not pass the 5000rpm so the engine will keep going till it reach the 5000rpm it will never cross it will stuk on it. so the car will run normal if the rpm does not reach the 5000rpm. i put it on a scaner and i got this:
    -00515.hall sensor-g40
    -00282.throttle valve
    -positioner-v60
    please reply thanks.
  2. Re: 00515 Hall Sensor G40 No Signal - HELP
    1840 Post(s)
    Nagnag, it would be better for you to start a new thread in the Golf 4 section of the forum and include your cars engine type code.
  1. Fault code 0203 (Hall effect sensor out of range)
    By Cawte12345 in forum Touran - Sharan - Caravelle
    Last Post: 08-12-2009, 01:37 AM
  2. VAG2008 At Leighton Hall 20th April
    By ninog60 in forum Shows & Events
    Last Post: 06-04-2008, 10:26 PM
  3. Japanorth Car Show, Haigh Hall Wigan
    By Jenni1188 in forum Shows & Events
    Last Post: 23-08-2007, 07:35 AM
  4. signal booster
    By bbb in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-05-2007, 08:02 PM
  5. Replies: 0
    Last Post: 07-09-2005, 08:31 PM
