Thread: Mk3 Golf - Removing the ignition switch
  1. Mk3 Golf - Removing the ignition switch
    Please help me,
    My mk 3 cabriolet ignition switch has gradually worn out, it sometimes starts, but never when you are in a hurry, I have purchased a new VW part. I have removed the cowling and unplugged the switch, but how do I remove it from the barrel? Looking at the new switch, there is obviously a retaining screw, do I have to dismantle the steering column to get to the very small screw? If so how do I remove the steering wheel which has an air bag fitted?
    Thanks in anticipation
  2. Re: Mk3 Golf - Removing the ignition switch
    Nov 2006
    I can't answer your problem, but I do have a solution in https://www.vwaudiforum.co.uk/forum/s...ad.php?t=25043
    According to the Haynes manual, getting the ignition from the barrel involves a drill and some graft, which to me isn't worth it for my K reg MK3.
  1. Dreaded ignition switch
    By joebrown9 in forum Golf MK3 - 1993 - 1999
    Last Post: 23-01-2008, 09:55 PM
  2. Ignition Switch does not engage Starter
    By massauto in forum Golf MK3 - 1993 - 1999
    Last Post: 21-10-2007, 09:36 AM
  3. Removing Ignition Switch 1990 Audi 90
    By HarrytheHorse in forum 80 - 90
    Last Post: 31-08-2007, 10:07 PM
  4. MK3 Ignition Switch trouble?
    By milescook in forum Golf MK3 - 1993 - 1999
    Last Post: 24-08-2007, 04:18 PM
  5. 94' Passat 1.9 TD - Dodgy Ignition Switch
    By paularcher in forum Passat - Archive Topics
    Last Post: 31-12-2006, 06:25 PM
