Thread: A6 Yellow ABS Light And Flashing Red Brake Light
  1. A6 Yellow ABS Light And Flashing Red Brake Light
    I have recently changed my front pads on my 1999 A6 because the wear picture was displayed on the dash along with a solid yellow ABS light, and a flashing red brake light. I placed pads with sensors on. The wires are in good shape and they are hooked up properly. I also checked the fluid and it is good. The problem now is the lights will not go away. Any Ideas?
  2. Re: A6 Yellow ABS Light And Flashing Red Brake Light
    May 2007
    Sounds more like an abs sensor out of alignment. If you have access to VAG-COM it will confirm.
    If you don't have access, you can always post a note for somebody in your area with it
  1. yellow engine warn light
    By paddymm in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-12-2007, 08:05 AM
  2. ABS light on with flashing red brake light
    By P471 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-11-2007, 09:26 PM
  3. ABS light on with flashing red brake light
    By P471 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-10-2007, 06:02 PM
  4. Sharan tdi 1997 - No brake lights and Heat coil light flashing
    By hawkz_2002_uk in forum Touran - Sharan - Caravelle
    Last Post: 16-09-2007, 07:20 PM
  5. Oil Level and yellow oil light
    By Trucypriot in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 22-10-2006, 01:53 PM
