Thread: Vag com error codes etc, 99 TDI Sharan.
Results 1 to 9 of 9
  1. Vag com error codes etc, 99 TDI Sharan.
    Dec 2007
    Redruth, Cornwall
    OK n00b alert...Im downloading the VagCom manual as I type so dont flame me please.....
    Just installed my dumb lead and software and ran a quick auto scan and got the following.
    VAG-COM Version: Release 409.1-US
    Chassis Type: 7M - VW Sharan
    Scan: 01,02,03,08,09,15,16,17,18,19,29,36,37,39,45,46,55 ,56
    Address 01: Engine
    Controller: 028 906 021 GT
    Component: 1,9l R4 EDC 00SG 1906
    Coding: 00002
    Shop #: WSC 00020
    No fault code found.
    Readiness: N/A
    Address 03: ABS Brakes
    Controller: 1J0 907 379 G
    Component: ABS 20 IE CAN 0001
    Coding: 12812
    Shop #: WSC 00020
    Address 09: Cent. Elect.
    Controller: 7M0 962 258 F
    Component: Multifunkt.Einheit 0001
    Coding: 04097
    Shop #: WSC 00020
    1 Fault Found:
    01135 - Interior Monitoring Sensors
    35-10 - - - Intermittent
    Skipping Address 15-Airbags
    Address 17: Instruments
    Controller: 7MO 920 920 K
    Component: Kombiinstrument 066a
    Coding: 00124
    Shop #: WSC 77824
    3 Faults Found:
    00779 - Outside Air Temp Sensor (G17)
    29-10 - Short to Ground - Intermittent
    00534 - Engine Oil Temperature Sensor (G8)
    01039 - Coolant Temperature Sensor (G2)
    End --------------------------------------------------------------------------------------------------
    Couple of questions.
    1, Wht didnt I get a result for each of the control modules it tried to scan? I guess I dont have all of them but 4 out of 18 seems low.
    The dash has been playing up so will investigate the sensors shown but how can I get more info on the module 09 fault to pin it down?
    Then, just for fun I went on the advanced settings to play...no idea what I was doing but went on the ABS test and it ran through a group of tests, told me to press brake pedal then made some noises ( from the ABS motor??? ) did this 4 times I think, 1 for each wheel and at the end said there was an error....the auto scan shown above says no error....
    Finally, how do I get live readings of engine speed, temperature etc etc?
    Will go and read the manual now I promise!
  2. Re: Vag com error codes etc, 99 TDI Sharan.
    1837 Post(s)
    Clear the dash codes, run the engine and see what comes back. Live data is in measuring blocks 08.
  3. Re: Vag com error codes etc, 99 TDI Sharan.
    Dec 2007
    Redruth, Cornwall
    Cleared the codes and ran the car. Tried VagCom again.
    Dash is clear ( guessed it would be as it hasnt played up since...just waiting ) but still have the interior fault.
    Coding: 04097
    Shop #: WSC 00020
    1 Fault Found:
    Where can I get detailed info as to what this sensor actually is? Have tried wiki and ross tech....
    As its interior monitoring, would I be correct in guessing its a sensor for the alarm?
  4. Re: Vag com error codes etc, 99 TDI Sharan.
    1837 Post(s)
    That is a fault with the interior motion sensors for the alarm, they are always going wrong.
  5. Re: Vag com error codes etc, 99 TDI Sharan.
    Dec 2007
    Redruth, Cornwall
    Thanks for that. How many sensors are there and are they expensive and/or dealer only item?
    Cheers and Merry Xmas.
  6. Re: Vag com error codes etc, 99 TDI Sharan.
    1837 Post(s)
    There are two ultrasonic motion sensor packs, one on each "B" pillar and they are part number 7M3 959 121 and cost £96.03 each.
  7. Re: Vag com error codes etc, 99 TDI Sharan.
    Dec 2007
    Redruth, Cornwall
    EEK! will see if I can find anything obvious first! I dont suppose I could replace with generic motion sensors? I guess they have all the control module stuff built in?
  8. Re: Vag com error codes etc, 99 TDI Sharan.
    1837 Post(s)
    Never tried it, they are unreliable on the Golf as well.
  9. Re: Vag com error codes etc, 99 TDI Sharan.
    Dec 2007
    Redruth, Cornwall
    Managed to check the alarm this morning...appears to be working with both sensors...mind you, the alarm horn sounds like someone has strangled a cat...a bit poor!
    Will leave it all for now as it's an expensive time of year!
    Thanks all.
    Merry Xmas.
  1. vw error codes
    By jat singh in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 25-09-2007, 08:53 PM
  2. Got some error codes, Can anyone help?
    By bamjimpat in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 30-08-2007, 10:01 AM
  3. Got some error codes, can someone help?
    By bamjimpat in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 29-08-2007, 07:11 PM
  4. Error Codes
    By andyd118 in forum Audi A4 - Archive Topics
    Last Post: 18-05-2007, 10:33 AM
  5. Vag-com Error codes... Help??
    By Beezo75 in forum VCDS - General Questions
    Last Post: 10-05-2007, 10:26 PM
