Thread: golf engine management light problem
  1. Exclamation golf engine management light problem
    Good morning
    Can someone help me with this problem please.
    Its a VW Golf 1.4 AXP Engine code. Registered 07/09/2000 on an X reg
    The catalytic convertor and both lambda sensors have been replaced and since then the engine management light comes on. After resetting the light the car is fine for three days until it's used on the motorway when the light comes on again. The cat and sensors have been checked and are fine. The coolant temp sensor has now been replaced and the egr valve stripped and cleaned.
    After more testing everything is fine and the car runs like a dream until its taken back out on the motorway and roughly three days later the light comes on again.
    The vehicle is only fuelled at Shell or Texaco so the cheap fuel problem is eliminated but i'm at a loss. Any had a similar issue etc plz?
  2. Engine emmisions
    Nov 2006
    i to have a vw golf 2.0 gti with engine emmissions light problem. I had spark plugs and leads and probes replaced and still get intermitent engine emmisions light warning coming on.
    Will try now i think with injector cleaner unless anyone got any other ideas?
    lucy car
    london/ UK
    Hi, were the catalist and/or the Lambda sensor genuine vag items? If they were, can u post the faults that set in the memory ? How many miles on the injectors ? Thanks.
  4. engine emmisions
    Nov 2006
    Hi the probes were genuine vw as were the spark plugs and leads. The light goes on for several days and then goes away for several weeks. The car is 2.0 gti with 58900 miles.
    Nov 2006
    the fault relates to the mixture and the mechanic reset the ecu to the factory settings but this has not cured the problem. when ever the car is diagnosed all settings and rpm etc are all in the correct parimeter.
  1. A6 2.5 TDI SE ENgine Management light
    By Red_Ade in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 22-04-2008, 11:23 PM
  2. Engine management light on
    By tonyjmoore in forum Polo - Derby - Lupo - Fox
    Last Post: 26-11-2007, 03:08 PM
  3. Engine Management Light
    By tony_anon in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-06-2007, 12:13 AM
  4. engine management light
    By vwgolfturbo in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 07-02-2007, 12:06 AM
  5. Engine management light came on
    By curiousgeorge in forum Audi A3 - Archive Topics
    Last Post: 05-01-2007, 10:27 PM
