Thread: flashing glow plug light
  1. flashing glow plug light
    hi all,
    i have a 03 plate 2.4 d transporter. the glowplug light started to flash and i noticed the side light bulb was out so have changed it but it is still flashing, can anyone help.
    thanks
  2. Re: flashing glow plug light
    Sep 2007
    Lancashire
    Quote Originally Posted by imanutter View Post
    hi all,
    thanks
    If you are close to us we will plug it in for you and do a free diagnostics check for you.
    Lancashire
    Pendle Performance
  3. Re: flashing glow plug light
    hi thanks but in hertfordshire, will it be best to get it read as it flashes constantly now?
  4. Re: flashing glow plug light
    7 Post(s)
    This is usually caused by a brake light switch fault. Are your brake lights working?
    ....That's the simple and easy fix, if not, get it read for faults and I hope it is nothing expensive.
  5. Re: flashing glow plug light
    thanks. have checked all the lights all seem ok so will book it in the morning. thank you for your help.
  6. Re: flashing glow plug light
    Nov 2006
    Its a common fault, if its defo not the brake light switch it will be the glow plug relay.
    Hope this is useful?
    Mark
  7. Re: flashing glow plug light
    hi had it to the dealer on sat said it was the injector was at fault and just ran cleaner through it.
    thank you
  1. Flashing Glow Plug Light??
    By TDi_B5 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-11-2009, 09:49 PM
  2. glow plug light flashing
    By rollingroadtune in forum Alhambra
    Last Post: 12-05-2009, 03:25 PM
  3. Glow Plug warning light flashing problem
    By Mark Hunt in forum Audi A4 - Archive Topics
    Last Post: 23-09-2007, 07:31 PM
  4. Glow plug warning light flashing.
    By Nebooaw in forum Passat - Archive Topics
    Last Post: 06-07-2007, 07:37 PM
  5. Glow Plug Warning Light Flashing
    By grange in forum Audi A4 - Archive Topics
    Last Post: 05-07-2007, 01:04 PM
