Thread: Mk 3 golf central locking failed
Results 1 to 8 of 8
  1. Mk 3 golf central locking failed
    0
    Hello everyone, pls can ayone help me, i bought a P reg Mk 3 golf diesel TDI estate (i believe that its not turbo but that another issue!) from a garage about 1 month back. Shes been great until last nite when i tried to unlock the door. The key rotates the same amount as before but without resistance and does not actuate . I had to climb through the back door (luckily i had room!) the buttons all work from inside. But i cant lock or unlock it from outside. Any suggestions. there has been a fault with the passenger lock since ive had the car the barrel just spins but as the driver lock locked the rest it was ok. Thanks
  2. #2
    0
    that sounds like the locking eccentric! i.e the padel shape bit's that mount to the barrel!
  3. #3
    Oct 2005
    Bristol
    Hello johnnie, suprapower is right.
    i have had the same problem on my golf. There is a "padel" that connects the door lock with the internal mechanism. Sadly the "padel" is made from monkey metal, the padel in the internal mech is strong enough but there is only a silly little hook in the end of the door lock barrel. You will need to replace this (or make your own (I did), you must make sure that you get the correct one though as i was told that there are severla different sizes.
    hope this helps,
    Mark.
  4. #4
    Nov 2005
    0
    Johnnie! SupraPower & MarkMK3 are right - it's yer paddle that's gone - it's a known fault on the MK3's... I did have a post several months ago on this if you do a search.
    Basically go to yer VW dealer / parts garage and get a new lock barrel / paddle kit - this should cost about 15 inlcuding VAT, pretty easy to fit - A Haynes manual will help you.
    One think to make sure is that you don't lose any of your tumblers / springs out of your current lock barrel, if you do that'll mean you'll need a different key for that lock (pain in the ****!) & make sure you grease the barrel / paddle / tumblers etc. up to prior to fitting to ensure smooth operation...
    Pretty simple that doesn't cost too much money either - you'll just need a Torx head bit to remove the door handle - and be careful with the white plastic retaining clip that's all too easy to drop down into the door cavity - not that it does much!!!
    Ta!
    Tim
  5. #5
    0
    Cheers fellas,
    I,ll give it a go and let you know!
    johhnie
  6. Fixed it!
    0
    Well gents (i guess you all are!) I fixed the locking, even though that after this long no one has tried to get in!
    Yup it was the hook broken off on the "eccentric" (doesnt look that eccentric to me!) I bought a replacement for 1.62 but i didnt change the part that the hook went into, so i had to file the hook down, not a good on such a flimsy part, so if anyone else is going to do it id suggest change the part that the hook goes into as it has been modified from the original.
    The part no. on the old bit was 1 HO 837 223 and the modified part was same with a B at the end.
    Well thanks again and i'll be back here if i have probs in the future (i hope not)
  7. Re: Mk 3 golf central locking failed
    Sep 2007
    0
    Hi all,
    Sorry to drag up the an old thread but this has just happened to the missus' mk3 golf GL. I've had the door card off and I think I can see what is described here which is that the bit of metal that connects the barrel to the mech has sheared. Access is VERY tight, how do I get better access to replace/repair the part? Is there a guide somewhere? Sounds common
    Thanks!
    Adam
  8. Re: Mk 3 golf central locking failed
    Oct 2005
    Bristol
    Hello Monty77, No need to be sorry to bring up an old thread, if i can help there is no problem. I found on my golf that when i took the lock out of the door, the "padle" came out with the lock. To re-fit the lock it was possible to insert the lock back into the mechanism and then line this up with the barel.
    Hope this helps, if not please feel free to reply to this and i will have another go at explaining it.
    Cheers,
    Mark.
  1. VW Golf Mk5 Central Locking reprogramming
    By Howdenboy in forum Golf MK5 - 2004 - 2009
    Last Post: 13-02-2010, 03:43 PM
  2. Central locking problem golf gt tdi
    By Ben33 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 10-03-2007, 09:06 AM
  3. Central Locking problem on a VW MK4 Golf
    By Shaz13230 in forum Golf MK4 - 1999 - 2004
    Last Post: 22-01-2007, 04:54 PM
  4. VW Golf (96) central locking problem?
    By munkifisht in forum Archive posts
    Last Post: 03-12-2006, 07:10 PM
  5. Golf 1.4 Central locking
    By zontal529 in forum Chat - Completely Off Topic - Sponsored by Shiply
    Last Post: 07-11-2006, 10:03 AM
Disclaimer: VW Audi Forum is an "independant enthusiast website", and is in no way related to any of the Worldwide Volkswagen,Audi,Seat,Skoda,Bentley,Bugatti,Porsche or Lamborghini group of Companies. For official up to date information on any of there vehicles, please visit the official websites. Any comments made throughout this website, are the views of the respective poster, and in no way represent the views of the VW Audi Forum Administration, or the worldwide Volkswagen & Audi Group of companies.
Copyright: Images used on this website by the Administration are "Copyright" of Volkswagen GB, Volkswagen AG (Germany), Audi GB, Audi AG (Germany), Volkswagen Motorsport GB, Volkswagen Motorsport AG (Germany), Audi Motorsport AG (Germany), Volkswagen Racing GB, Bentley, Bugatti, Porsche and Lamborghini. No image can be replicated by anyone WITHOUT the relevent Companies written permission.
Page copy protected against web site content infringement by Copyscape
- VW AUDI Forum - The No1 VW Audi Forum - Volkswagen (VW) - Audi - Seat - Skoda - Bentley - Bugatti - Lamborghini - Porsche - VW Audi Forum -
