Thread: MAF Implausible Signal
  1. MAF Implausible Signal
    My car's performance has decreased drastically. The Scan tool registers 16485 p0101 Implausible Signal from the MAF. We swapped a new MAF but no difference. There are no blockages in the inlet and the wiring seems to be OK. If the code is cleared it only appears after the car has been running for a few minutes and the MAF will then stick in a default no 550 for the reading..
    Anybody come across anything similar?
  2. Re: MAF Implausible Signal
    7 Post(s)
    An implausible signasl error is usually given if there is a total break in the circuit. As you've checked the component by replacing it, I'd turn my attention to the wiring.
    Tricky I know, but try and trace it back along the loom looking for damage.
  1. Strange Signal Problem
    By VWLeonG in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-03-2010, 09:30 PM
  2. Error Code- Potentiometer for EGR?? Implausible signal ??
    By ardasaliah in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 13-01-2008, 09:57 PM
  3. Remote signal getting weaker
    By ozpom in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 16-05-2007, 09:26 AM
  4. signal booster
    By bbb in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-05-2007, 08:02 PM
  5. sharan am radio signal
    By 1truegeordie in forum Touran - Sharan - Caravelle
    Last Post: 12-01-2007, 08:31 PM
