Thread: no boost pressure
  1. Exclamation no boost pressure
    hi everyone, my 225bhp s3 dosn't seem to have any boost in low gearsand intermittantly when trying to accelerate in top gear the rev counter would just jump to 4000 rpm but with no acceleration of the car, so i recently had it into a garage and they fitted a new diaphragm in the recirculating valve as the old one had split, but i still dont feel any turbo boost in lower gears.
    can anyone help?
  2. Re: no boost pressure
    Jul 2007
    Cheshire, or my A6
    Have you tried putting in new oil. The Audi's are very picky about the oil you put in them. Make sure it is the VAG stuff. Dearer, but well worth it.
    Paul
  3. Thumbs up Re: no boost pressure
    ok, i'll try that thanks very much.
    steve.
  4. Re: no boost pressure
    cheers, i'll try it.
    steve.
  5. Re: no boost pressure
    The only accurate way to test the boost is with a diagnostic tester reading the MVB (mesaured value blocks) its checked in 3rd gear full throttle at 2000rpm untill 3000rpm. Air mass meter and charge pressure control solenoid valve can cause lack of power somtimes even without a fault code stored.
  6. Re: no boost pressure
    thanks for the reply. would it be best to take the car to an audi dealer for these tests.
    cheers steve.
  7. Re: no boost pressure
    Might be a good idea unless you have access to a tester but be specific on what you want checked whether its just the boost pressure or for a lack of power cos the charge could get a bit heavy in a dealer.
  1. oil pressure
    By 01394graham in forum Polo - Derby - Lupo - Fox
    Last Post: 12-09-2007, 10:31 PM
  2. T4 2.5TDi boost pressure - what should it be?
    By DubDick in forum The Commercial Range
    Last Post: 04-09-2007, 12:26 PM
  3. S4 Oil Pressure?
    By SnakeEyes in forum Archive posts
    Last Post: 30-03-2007, 06:28 AM
  4. mk3 tdi no boost
    By robert1z in forum Golf MK3 - 1993 - 1999
    Last Post: 12-03-2007, 10:07 PM
  5. boost
    By lee2u in forum Audi A4 - Archive Topics
    Last Post: 30-01-2007, 10:05 PM
