Thread: 17965 overboost, is my acuator doing what it is supposed to?
Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
  1. Re: 17965 overboost, is my acuator doing what it is supposed to?
    May 2010
    Tregarth UK
    The EGR still looks really shiny (bought the car in 2012) so that could have been new, I can't tell if the N75 was changed, but they said that was what the problem was. They didn't charge me as it was having problems not long after driving it away having bought it. I'll have a look at how tricky driving it without the MAF is. Funnily enough when I have not long pulled over fueled up, and then if I boot it it is hesitant and will go into limp mode if I continue booting it. But other than that and when it's cold, it seems to be behaving itself.
    VW Passat Estate SE 1.9pd Tdi (130 AWX) 2002 162k
  2. Re: 17965 overboost, is my acuator doing what it is supposed to?
    As I say, I'm clutching at straws with the MAF thing but anyway, it goes like this:
    Disconnect it, If whilst driving it, there is no difference or its the same, change the MAF (proper ones are expensive)
    If on the other hand it now drives like a total dog- you'll have virtually no boost it feels like, then its not the MAF.
    (Starting it with it disconnected will throw a code.)
    1 1 0
  3. Re: 17965 overboost, is my acuator doing what it is supposed to?
    May 2010
    Tregarth UK
    Sounds easy enough I'll have time to do this on Thursday, and see what the results are. Good luck with yours in the mean time
  4. Re: 17965 overboost, is my acuator doing what it is supposed to?
    Oct 2014
    TAUNTON . SOMERSET
    Clean the turbo is the first thing replace vacuum lines on the way. Also clean intake manifold egr intake hoses maf sensor and map sensor with electric friendly cleaner. Thats will do job without further questions.
    A4 B6 1.9 QUATTRO 07463021112
  5. Re: 17965 overboost, is my acuator doing what it is supposed to?
    May 2010
    Tregarth UK
    Thank you for the pointers, pretty much out of my skill/tool range, so could well buy reconditioned turbo, get garage to do rest.
  6. Re: 17965 overboost, is my acuator doing what it is supposed to?
    Oct 2014
    TAUNTON . SOMERSET
    Yeah if u rich
  7. Re: 17965 overboost, is my acuator doing what it is supposed to?
    #17
    Pembrokeshire
    22 Post(s)
    i think he is called kieran, not richard.
    0 3 0
  8. Re: 17965 overboost, is my acuator doing what it is supposed to?
    #18
    May 2015
    Hinckley
    Air intake off and see the carbon build up happened to me I was in your situation about 2 month ago also egr delete if you haven't already 👍
    1 1 0
  1. Please Help Where is this plastic clip supposed to be ?
    By leungha in forum Golf Plus
    Last Post: 13-08-2013, 05:16 PM
  2. Can you damage The VNT acuator by manual moving actuator rod by hand?
    By leeanderin in forum Golf MK5 - 2004 - 2009
    Last Post: 08-10-2012, 09:55 PM
  3. Question What is the 'Mode' button supposed to do?
    By DougJohnSmith in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 23-03-2011, 02:19 PM
  4. Whats mine supposed to be..?
    By LJW61 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-08-2008, 06:58 PM
  5. 17965---overboost
    By NinjaXP in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-08-2007, 09:30 PM
