Thread: Door Lock
Results 1 to 10 of 11
  1. Door Lock
    1998 A6 C5 saloon. Closed the door today and the interior lighs stay on. The display shows the drivers door is not closed. Several attemps but the door indicater shows it is open. Any ideas. I'll take a look when it stops raining. Regards Peter
  2. Re: Door Lock
    Microswitch in door lock broken.
  3. Re: Door Lock
    Jan 2009
    Winchester, Hampshire, U.K.
    Quote Originally Posted by CharlesElliott View Post
    +1 (or stuck down - can't remember which way it works) either way, 99% defo it's the microswitch.
    2003 3.0 quattro Avant
  4. Re: Door Lock
    The microswitch is F2 ( part of the lock ) The diagram shows that the wire connected to this does not go via the 15 pin connector or to J429. Does anyone know where it goes. Regards Peter
  5. Re: Door Lock
    F2 connects to track 131 which feeds the door warning and entry lights. These in turn go to track 52 and 18 which goes through a connector into J429.
  6. Re: Door Lock
    Ayrshire, Scotland
    18 Post(s)
    check the switch, it proabably still works, the rubber pad will have come of the switch and it will now be missing the striker, you can remove it from the latch assembly pretty easily, i buffed the 2 locating pins off my switch and moved it towards the striker
    regards
    Andy
    2001 Audi A4 Saloon 2.0
    2000 Audi Allroad 2.5TDI V6 quattro
    Fully licenced Ross-Tech VCDS Interface
    Air Suspension Compressor Repair Kits: www.bagpipingandy.com
  7. Re: Door Lock
    Jan 2009
    Never mind tracks & connectors, it's the mechanical operation of the microswitch (or lack of it) that's your problem. I was able to repair it on my first A6 as it was only stuck down but was actually broken on the current A6. The microswitch would be a run of the mill type available from RS Components or Maplins except half of the plastic body is special to Audi with two locating pins as bagpipingandy has said. It may be possible to find the standard switch (the one on my first A6 was made by Burgess) & combine the two halves of the body. More likely is to cut the two wires, (leave all the length on the lock side - it's hard wired in) & splice solder in a standard switch without the locating pins & devise your own way of locating/securing it. I know this has been done & isn't too difficult. Alternatively, you can replace the whole lock assembly which, IMHO (through experience) is definitely the best way to go - albeit the most expensive (around £120, although you can get cheaper on ebay - I just wouldn't trust them). I fitted a new lock mechanism three months ago and Audi have now modified the troublesome area so it is now better engineered. The likelyhood is that your whole lock mechanism will have seen better days & is very capable of causing some serious problems, eg. The door refusing to open & trying to sort that is not funny.
    Have a look at this thread:
    door lock problem?
  8. Re: Door Lock
    Jan 2009
    Have you sorted it Peter?
  9. Re: Door Lock
    Presently have a nasty chest infection so no action taken yet. Regards Peter
  10. Re: Door Lock
    Jan 2009
    Best wishes Peter - I hope your recovery is rapid.
  1. Replies: 22
    Last Post: 18-01-2022, 05:45 PM
  2. Replies: 0
    Last Post: 02-02-2015, 11:16 AM
  3. Replies: 3
    Last Post: 23-03-2013, 10:15 PM
  4. Replies: 0
    Last Post: 12-01-2012, 07:07 PM
  5. Please Help rear door wouldn't lock from inside (using 'lock' button)
    By angermayer in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-05-2011, 07:58 AM
