Thread: Audi A6 C7 fuel system and warranty problems
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 43
  1. Audi A6 C7 fuel system and warranty problems
    Feb 2015
    London
    I'm the owner of 2012 Audi A6 2.0 tdi. 3 days ago car has just stopped with no warning lights on dashboard. Car was taken to the dealer as it's 57 000m and less than 3 years old.
    Not even knowing what was the issue I expected the car to be repaired under warranty. Today, I received call from dealer. They are saying that it's fuel pump damaged and it 's very likely that someone in the past put petrol in the car ( they're assuming this looking at the type of damage). BUT THEY ACTUALLY DID NOT FIND ANY PETROL IN THE CAR!! ONLY DIESEL That's something I don't understand. That's why they might not cover it under warranty. They say that they will check if change of fuel pump will help. If it will, they'll do it under warranty. If not they will decline warranty. For me it's obvious that if the pump it's damaged, all fuel system needs to be repaired. Changing pump won't help. I feel like they're making an idiot of me!
    Any suggestions,please
  2. Re: Audi A6 C7 fuel system and warranty problems
    Apr 2014
    Derby
    30 Post(s)
    No, they aren't taking the P. If as they suspect the pump is damaged due to previous fuelling error, then they can't be expected to replace the entire fuel system under warranty. Its not a fault with the car due to faulty parts as such, but human error, not yours granted. You will do well if they replace the pump under warranty. This is the risk you take buying second hand.
    Current Fleet
    2017 Audi A6 Avant BiTdi
    2008 BMW Z4M Roadster
    2003 Clio 172 Cup
  3. Re: Audi A6 C7 fuel system and warranty problems
    Aug 2014
    Shrewsbury, Shropshire, England
    Sorry I disagree. If you buy a car with a warranty of x y or z months then that is it final. If they aren't prepared to repair the car under warranty this is a clear breach of trading standards.
    I run my own garage door company and if the home owner sells their house the 10 year warranty that comes with the door still continues. You accept the fact you pay a few quid extra for that undisputed warranty.
    I would request the repair be carried out under the warranty offered or consider handing the car back.
    Andy
  4. Re: Audi A6 C7 fuel system and warranty problems
    Southern County Softy
    20 Post(s)
    If the Garage Door you supplied and fitted is damaged by vandalism does your warranty cover it ?
    A4 2.5 tdi QS (mapped)
  5. Re: Audi A6 C7 fuel system and warranty problems
    Aug 2013
    18 Post(s)
    Not sure why the whole fuelling system would need to be replaced unless it had been contaminated so I would be hopeful it was just a faulty pump and a valid claim. IMHO using the wrong fuel (or contaminated fuel) is never a warranty issue. You might have a claim if you bought the car recently and an independent assessor proved the damage/misfuelling was done prior to purchase… the seller would then be responsible for any repairs.
    Total speculation, but with the number of incidents I would guess they have some sensor or other method of detecting incorrect fuel use even if there is currently no petrol in the system.
    @ Pikey Narna, I see where you’re coming from, but it’s akin to someone using the wrong lubricant on the garage door then making a claim when it seizes up.
  6. Re: Audi A6 C7 fuel system and warranty problems
    Apr 2014
    Derby
    30 Post(s)
    The OP doesn't state where he bought the car, just that he is trying to use the original 3 year car warranty. I agree if the car was bought 2nd from a dealer then that is worth looking at, but will be a nightmare to make stick.
    Current Fleet
    2003 Clio 172 Cup
  7. Re: Audi A6 C7 fuel system and warranty problems
    Aug 2013
    18 Post(s)
    Might still be someone else that’s to blame:
    Poorly A6
  8. Re: Audi A6 C7 fuel system and warranty problems
    Feb 2015
    London
    Thank for your answers,
    I did 20 000 m on the car. Never put any petrol and car didn't make any problems at all. I called couple of experts including: car independent inspector, diesel fuel system specialist and others. All of them saying that Audi can't prove that there was petrol in the car at any point, if they didn't actually find it. They say that it would damage the system straight away, not after 20000 m.
  9. Re: Audi A6 C7 fuel system and warranty problems
    Feb 2015
    London
    By the way they didn't say that they've got any sensor or system to prove. They say that it ,,LOOKS LIKE... or IT IS LIKELY looking at the damage. It's just their expert eye making decision. NO EVIDENCE, TESTS etc.... In most of the times, if the pump is damaged, there's metal pieces from it in the fuel tank, injectors etc. Basicly, it should be all changed
  10. Re: Audi A6 C7 fuel system and warranty problems
    Aug 2013
    18 Post(s)
    Sounds like you’re sorted then… if they refuse a warranty claim then ask for their reason in writing.
    The same applies to your own assumptions though… you will need to prove there is a fault and/or requirement to change the whole fuel system. I would have thought a dealer would love that amount of legitimate warranty work.
  1. 1.9 Tdi 2000 Engine fuel system problems.
    By GreenA4Tdi in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-02-2013, 07:12 PM
  2. Replies: 3
    Last Post: 05-08-2012, 04:59 PM
  3. Question 2.5TDi starting problems, fuel system relay?
    By Pentti in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-07-2011, 12:11 PM
  4. Replies: 2
    Last Post: 24-11-2010, 11:35 PM
  5. Audi 1.8T Fuel Trim: Bank 1 (Mult): System too Lean
    By RedZed2009 in forum VCDS - Help Requests
    Last Post: 03-07-2010, 02:50 PM
