Thread: A4 Cabriolet FM Aerial
  1. A4 Cabriolet FM Aerial
    Sep 2013
    A, A
    Hey!
    Apologies if this has been answered before. The FM reception in my cabrio is awful. I understand that there there is a common issue with the cable deteriorating at the flexible cover on left side of the boot.
    I've not had a chance to have a good look at it, but understand that others have successfully repaired the aerial cable, but I wonder if anyone has ever replaced the whole cable, or even know if this is possible?
    At the moment I am using a Parrot Asteroid (worse heap of ***** EVER), but at least I can use iPhone's connection to access internet stations rather than using the FM.
    I am looking to replace said unit with a double din unit (not sure which yet - Maybe a Panasonic unit?), either way I would like to get the FM aerial sorted before hand.
    Thanks guys
  2. Re: A4 Cabriolet FM Aerial
    1837 Post(s)
    Which system do you have, Chorus, Symphony, Bose, nav and the cars year?
    The usual problem is the co-ax in the boot hinge conduit being broken and you have to replace this, typically with part number 8H5 035 550 AA which is £60 from Audi.
  3. Re: A4 Cabriolet FM Aerial
    Feb 2015
    Cambridge
    I recently fixed our radio with a £7.30 windscreen aerial. It has to be powered tho' so i wired it to the asc button so its powered when the ignition is on.
  1. Cabriolet Power roof not Working / Electric aerial extended -stops roof from lowering
    By Q7quattro in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 22-02-2014, 05:06 PM
  2. A4 Cabriolet aerial problem
    By lscolman in forum In Car Entertainment
    Last Post: 14-12-2013, 11:02 AM
  3. Question my cabriolet aerial
    By cjh8280 in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 26-02-2010, 05:45 AM
  4. A4 cabriolet radio aerial
    By bazander in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 05-02-2009, 06:03 PM
  5. Question A4 cabriolet radio aerial
    By davidhrushton in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 14-08-2008, 03:52 PM
