Thread: Audi 06 1.9tdi cold start issues
Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 43
  1. Audi 06 1.9tdi cold start issues
    #31
    Jan 2014
    Which also connects to the black right hand side pipe fitting of this pump
  2. Re: Audi 06 1.9tdi cold start issues
    #32
    Jan 2014
    The black nipple was a little wobbly too
  3. Re: Audi 06 1.9tdi cold start issues
    #33
    Aug 2011
    Meath
    Quote Originally Posted by Demo8Dan View Post
    Mnnnnn
  4. Re: Audi 06 1.9tdi cold start issues
    #34
    Jan 2014
    Tandem pump vacuum issue maybe the cause you recon?
  5. Re: Audi 06 1.9tdi cold start issues
    #35
    Aug 2011
    Meath
    Any diesel smell off the engine oil?
  6. Re: Audi 06 1.9tdi cold start issues
    #36
    Jan 2014
    If you read Half way Down this thread it sound the same issue
    Please help with my smokey AVB :-( [Archive] - VW AUDI Forum
  7. Re: Audi 06 1.9tdi cold start issues
    #37
    Jan 2014
    It must be sucking in air frm that wobbly pipe fitting off the tandem pump
  8. Re: Audi 06 1.9tdi cold start issues
    #38
    Jan 2014
    But now I have just read this saying it's supposed to be loose... It defiantly had a leek by the one way valve before I pushed it in properly because when I was moving it I could hear it pssss noise from it. Il try cold start in the morning and let you know the news.
  9. Re: Audi 06 1.9tdi cold start issues
    #39
    Jan 2014
    Problem solved thanks Doctle great member
  10. Audi 06 1.9tdi cold start issues
    #40
    Jan 2014
    I have to sadly say the problem is still there, it has been sitting for a while so took it for a long drive after it started and it also has a boost issue fault code as it doesn't go well when the pedal is thrown down
  1. Cold start issues
    By cos192000 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 16-12-2013, 11:38 PM
  2. Question T5 Cold Start Issues
    By Monkey117SE in forum The Commercial Range
    Last Post: 26-05-2013, 11:09 PM
  3. Cold Start Issues
    By Dino07 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 19-12-2010, 12:40 PM
  4. Question cold start audi a4 1.9tdi
    By jonny l in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-02-2009, 09:56 PM
  5. Audi 80 2.0 SPI cold start issues?
    By panther12 in forum 80 - 90
    Last Post: 13-08-2007, 12:57 PM
