Thread: small door handle cable replacement
  1. Lightbulb small door handle cable replacement
    A Galaxy Far Far Away....Derry
    Hi All,i have a 2002 passat b5.5. i have got the little cable that goes between the front outer passenger side handle and the lock.Have had conflicting ways on how to change this as it has nipped.Can it be replaced from the outside part of the handle or do i have to remove inner panel with window motor etc? either way it looks footery and awkward.going to give it a lash tonight,so any feedback would be much appreciated
    thanks in advance for any advice.
    Jacko
    Jack
  2. Re: small door handle cable replacement
    May 2007
    17 Post(s)
    Hello Jacko.
    I'm sure someone has probably managed to replace that little cable without stripping the door but it would probably be quicker/less frustrating just to remove the window regulator panel, lock assembly, etc. Imagine if you had spent the best part of an hour trying key hole surgery then dropped your new cable inside the door and ended up having to strip it all anyway.
    Jim.
    1 1 0
  3. Re: small door handle cable replacement
    update.have the handle off and the locking cyclinder part out,got the old nipped cable and the bit that hooks ont te lever off.Does anyone know of a gizmo for reattaching the new cable onto the lever? seems like it has to go on a certain way then twist to lock in.Long nose pliers and patience?
    cheers folks
    Jack
  4. Re: small door handle cable replacement
    new update: got the door stripped down and took off inner panel,all was going swimmingly until i dropped the cable,it has fallen into the inner door skin and i can retrieve it!! just typical of my luck.
    Jack
  1. Please Help B6 Sport - Door handle broken bowden cable?
    By Scottiedogg in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-06-2012, 08:45 PM
  2. A8 keyless entry door handle replacement
    By davetye in forum A8 - S8 - V8
    Last Post: 29-08-2011, 01:49 PM
  3. Help D3 exterior door handle replacement
    By instrutec in forum A8 - S8 - V8
    Last Post: 21-05-2011, 06:28 PM
  4. MK3 Estate back door handle replacement.
    By Perkele in forum Golf MK3 - 1993 - 1999
    Last Post: 16-07-2009, 12:15 PM
  5. A4 Avant Door Handle Cover Replacement
    By thommo in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 12-05-2009, 06:23 PM
