Thread: Bolt sheared in subframe couple other question
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
  1. Bolt sheared in subframe couple other question
    Jan 2015
    wolverhampton uk
    hi thanks for taking a look advice gratefully received
    golf mk5 2004 early reg as title I sheared a bolt trying to change wishbone on drivers side another one still in feels like it will do the same and im just thinking would it be easier to change subframe as that's the one that sheared (in subframe) plus ive got to get gearbox out anyway also I cannot find the obd plug its not in driver footwell unless im blind ive got a orange steering wheel on dash I bought it with a sheared gearbox mount so ive got to replace that engine code is bca gearbox fxq thanks in advance
  2. Re: Bolt sheared in subframe couple other question
    Aug 2011
    Meath
    I uses to use easy outs to remove broken studs but they're hit and miss. I decided to try an old spline bit. First drill a hole in the stud use a center punch and drill in 3/4 inch or so. Get an old torx or spline bit slightly larger than the hole and hammer it home. You then need to spray on some plus gas and leave it for half an hour. It should then easily screw out with a 10mm spanner. It's a bit much replacing a subframe for a broken bolt.
  3. Re: Bolt sheared in subframe couple other question
    Jan 2015
    wolverhampton uk
    Doctle odd thanks for the reply and advice my steering light is on (orange and I might have to do the electric steering rack motor?) I will attempt the advice you've given me am I right in thinking the bolts from wishbone only go through subframe not body ive still got to do passenger side best to do both I believe and im expecting problems
    if the electric rack steering motor?? is funked ive got to drop subframe anyway would like an easier route but from looking on net and Haynes manual its vague to say the least
  4. Re: Bolt sheared in subframe couple other question
    Aug 2011
    Meath
    If your doing it on the ground removing the rack is as much fun as a barium enema
  5. Re: Bolt sheared in subframe couple other question
    Jan 2015
    wolverhampton uk
    thanks again for replying the diagnostic plug is still evading me its not in drivers footwell and yeah it is on the ground well axle stands so its going to be fun
  6. Re: Bolt sheared in subframe couple other question
    Aug 2011
    Meath
    Quote Originally Posted by daz2208 View Post
    Take out the plastic panel in the drivers footwell the diagnostic plug has maybe been pushed out of place
  7. Re: Bolt sheared in subframe couple other question
    Jan 2015
    wolverhampton uk
    Quote Originally Posted by Doctle Odd View Post
    im seriously struggling now its not there at all I will take some pics when phone charged and post them
  8. Re: Bolt sheared in subframe couple other question
    Aug 2011
    Meath
    Check if theres a panel that pulls off under the ashtray
  9. Re: Bolt sheared in subframe couple other question
    Jan 2015
    wolverhampton uk
    is there any logical reason why it would have been cut out taken out or kidnapped and held to ransom
  10. Re: Bolt sheared in subframe couple other question
    Jan 2015
    wolverhampton uk
    will do now by under you mean take ashtray out ??
  1. Front wishbone mounting bolt sheared off!!
    By kevdood in forum Polo - Derby - Lupo - Fox
    Last Post: 18-11-2010, 10:22 PM
  2. Rocker cover bolt sheared & fuel filter question
    By SammoVWT in forum Golf MK3 - 1993 - 1999
    Last Post: 04-07-2010, 03:55 PM
  3. How To 80 front subframe bolt torques
    By 80SPORTSEMAN in forum 80 - 90
    Last Post: 14-04-2009, 09:09 AM
  4. A4 front suspension sheared bolt
    By benjwom in forum New Member Introductions
    Last Post: 10-04-2009, 03:33 PM
  5. Please Help ive sheared my top link bolt!
    By willster in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-11-2008, 01:56 PM
