Thread: Jerking or hesitating on high acceleration on pickup
Results 1 to 10 of 15
  1. Jerking or hesitating on high acceleration on pickup
    Dec 2014
    Leeds
    I've got an A6 2007 2.0 TDI SLine diesel automatic
    If I give high acceleration to pickup it struggles / jerks / which means that it not a smooth pick up
    Please help me
  2. Re: Jerking or hesitating on high acceleration on pickup
    May 2014
    Darlington
    78 Post(s)
    Have you had the car scanned and when was the gearbox services and the fuel filter changed?
  3. Re: Jerking or hesitating on high acceleration on pickup
    Dec 2014
    Leeds
    I think it was over a year back the car was serviced
    also the service booklet does not mention about cam belt change and it has done 100k
  4. Re: Jerking or hesitating on high acceleration on pickup
    May 2014
    Darlington
    78 Post(s)
    Does it say anything about the gearbox or fuel filter? If not I would have them changed.
  5. Re: Jerking or hesitating on high acceleration on pickup
    Aberdeen
    63 Post(s)
    Get the cambelt checked ASAP. It is supposed to be 5 years or mileage (maybe 75,00 in your case) which ever comes first. If it hasn't been done you are well past it. Check with Audi and if unsure whether it was done, get it changed.
  6. Re: Jerking or hesitating on high acceleration on pickup
    Dec 2014
    Leeds
    I've checked now and the cambelt was changed at 78k couple of years back and it is now 107k.
    what else could be the issue
  7. Re: Jerking or hesitating on high acceleration on pickup
    Oct 2014
    Mansfield UK
    Had a problem with my 2.0 TDI not pulling under hard acceleration just after I got it , garage had it in and said no fault codes so diagnosed faulty turbo so they removed it & had it reconditioned, still the same so after trying a few other things they gave up and it had to go to another garage who figured out all the issue was that fuel filter needed replacing , did that and was fine .
    Not sure if same problem for you but prior to changing filter car drove fine under normal driving, only hesitated when accelerating hard to overtake etc so didn't pick up on it on initial test drive before buying the car
  8. Re: Jerking or hesitating on high acceleration on pickup
    Nov 2012
    Somerset UK
    Quote Originally Posted by Yokietoks View Post
    I think you've been advised to get the transmission fluid changed, at 107k it will be coming up to it's 3rd fluid change...if it's never been done then your transmission is liable to fail and cost ££££'s
  9. Re: Jerking or hesitating on high acceleration on pickup
    Dec 2014
    Leeds
    Just been to a garage and he said the fly wheel might need replacing. Any thoughts ?
  10. Re: Jerking or hesitating on high acceleration on pickup
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    I'd like a bit more than a 'might' before committing to that job, sounds like you need to check up on your servicing and get a full scan done for starters.
  1. 2.0 TFSI QUATTRO jerking during acceleration
    By staggie75 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 03-06-2010, 10:12 PM
  2. Bora TDi 110 hesitating on acceleration
    By tallpaulselfrid in forum Bora - 1998 - 2005
    Last Post: 10-08-2009, 10:13 PM
  3. Please Help VW Polo 1997 hesitating on acceleration
    By Deccer in forum Polo - Derby - Lupo - Fox
    Last Post: 28-04-2009, 01:54 PM
  4. engine hesitating on acceleration
    By hongkongstuey in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-06-2008, 04:18 PM
  5. hesitation / jerking after heavy acceleration
    By Chris Russell in forum Audi A3 - Archive Topics
    Last Post: 14-11-2007, 10:24 AM
