Thread: Auxillary drive belt tensioner has broken
  1. Auxillary drive belt tensioner has broken
    Jan 2009
    Nuneaton England
    6 Post(s)
    Hi All,
    I have a VW Polo 1.9SDI 2003
    The auxillary drive belt tensioner has snapped but I can not see how to remove it?
    Can anyone help me with a picture or instructions please
    Thanks all
  2. Re: Auxillary drive belt tensioner has broken
    Aug 2011
    Meath
    The bolt is a good bit towards the bell housing, you should be able to see it there
  3. Re: Auxillary drive belt tensioner has broken
    Feb 2012
    Here is a picture of the bolt location, If you stick a socket on an extension in the hole (circled in red) you should be able to reach the bolt head. Can be quite fiddly to get the bolt out and watch your fingers on the edge of that hole as on mine they were pretty sharp.
    It may be worth checking your alternator pulley as this is a common cause of failure in the aux drive belt tensioner. To check the pulley you need to carefully stop the alternator itself from rotating (stick a screwdriver through one of the gaps to jam the cooling fins(Carefully!)) then gently try and turn the pulley, it should turn easily in one direction but not move at all in the other direction. If it will not turn in either direction or there is much resistance then it needs replacing (Not too expensive but a pain to get the alternator out). Also may be worth changing the belt too.
    Hope this helps, sorry for dodgy photo was dark when I took it!
  4. Re: Auxillary drive belt tensioner has broken
    Aug 2013
    London
    Here's one I prepared earlier...
    Drive belt tensioner replacement - Engine, Transmission and Exhaust - Club Polo Forum
    Getting the old one out should be easy. Fitting the new one is a bit of a squeeze.
    What I did is remove the wheel and inner cowling for side access, then refit the wheel so it could be put on ramps for access underneath.
    Mine failed again after 12 months. I suspect the root cause as mentioned by RR above and as I've read before, is sticking alternator clutch. While idling you can hear it 'tweeting' like there's birds nesting in there.
  5. Re: Auxillary drive belt tensioner has broken
    Jan 2009
    Nuneaton England
    6 Post(s)
    Hi All,
    Many thanks all, got it sorted today, happy days
    A bit of a fiddle getting the new one in and making sure I didn't push the retaining bolt out.
    jimboe your link does not open?
  6. Re: Auxillary drive belt tensioner has broken
    Aug 2013
    London
    Quote Originally Posted by mumutley View Post
    Hi All,
    Glad you got it sorted.
    Looks like the other site was down for a while. The link is working again now.
  1. Auxillary Belt Tensioner Getting Hot
    By jonty89 in forum Touran - Sharan - Caravelle
    Last Post: 06-06-2012, 08:23 AM
  2. Question auxillary belt tensioner
    By neil mahoney in forum Golf MK5 - 2004 - 2009
    Last Post: 27-07-2010, 09:43 PM
  3. Auxillary Belt Tensioner Failure
    By hagis in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 09-01-2010, 01:21 PM
  4. Auxillary belt tensioner woes
    By porcher in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-07-2007, 09:35 PM
  5. Passat TDI auxillary drive belt tensioner
    By vincentbob in forum Passat - Archive Topics
    Last Post: 19-01-2007, 04:54 PM
