Thread: Decrease in DAB signal strength
  1. Decrease in DAB signal strength
    Sep 2014
    Tewkesbury UK
    Hello
    I have retrofitted a Sonichi dab receiver jn my Golf Mk6 which i use in conjunction with my non dab RNS510. My problem is that when i switch on the ignition, without starting, the signal strength of the signal falls from 100% (15 bars on the strength indicator) to 6 bars. The aerial is in the rear window and switching on the demister does not affect the signal. Can anyone please help or maybe guess at the cause.thanks
    Meirion
  2. Re: Decrease in DAB signal strength
    Sep 2014
    Tewkesbury UK
    Solved with a hint from a post in the Audi forum. It had to be something that powered up with ignition on. The culprit was a Griffon usb converter fitted in the boot 12v socket. Removed this and the signal was back up to 100%.
  1. Heated Rear Screen causes loss of DAB signal
    By N16E in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 09-12-2014, 05:03 PM
  2. 2012 Passat RNS 510 without DAB, how can I retrofit DAB?
    By gtx2010 in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 29-10-2013, 12:49 PM
  3. 3.0 TDI clutch strength for remapping
    By dod1e in forum 3.0l - Engine
    Last Post: 13-06-2011, 09:55 PM
  4. Question How can I enhance the Aerial strength?
    By carys220 in forum Golf MK4 - 1999 - 2004
    Last Post: 09-09-2009, 10:53 PM
  5. Decrease in MPG... why??
    By Loofer in forum Chat - Anything with wheels
    Last Post: 01-08-2007, 07:31 PM
