Thread: What audi engine ?
Results 1 to 10 of 16
  1. What audi engine ?
    Nov 2014
    bournemouth
    Hi All
    I have a vw t25 crew-cab, I had the engine changed a few years ago the guy that installed it has moved to France and cant get hold of him anymore.
    I am not sure what engine it is I cant find any numbers on the engine. The numbers off the ecu comes back as audi 1996 but seems the same for petrol and diesel all I know is it's a 1.9 tdi engine and has no diagnostics plug it has gone into limp mode I have had a new turbo put on it as the outer housing was cracked this has still not made any difference I am going to try somethings which I have read on this forum.
    But would still like to know what engine it is can anyone tell me a way to find out or if I can take pics of certain things you can tell me the engine type.
    Thanks Tom
  2. Re: What audi engine ?
    Pembrokeshire
    22 Post(s)
    welcome.
    take some pics, from all angles, including the injector pump and injectors.
  3. Re: What audi engine ?
    Nov 2014
    bournemouth
    ok thanks I will post tomorrow
  4. Re: What audi engine ?
    Nov 2014
    bournemouth
    Also forgot to ask as there is no diagnostic plug it there any other way of reading the ecu ?
  5. Re: What audi engine ?
    46 Post(s)
    Part number on the ecu? The engine number should be stamped on the block somewhere I think along with a sticker on the timing belt cover.
  6. Re: What audi engine ?
    Aug 2011
    Meath
    If it's a tdi the plug is different from a 16 pin one fitted to a car. I think it's a round connection as it's a re-badged Merc
  7. Re: What audi engine ?
    Nov 2014
    bournemouth
    welcome.
  8. Re: What audi engine ?
    Pembrokeshire
    22 Post(s)
    ok, so its a 4 pot tdi, possibly a 1z from an audi 80. it should have a diag socket, its in the fuse box on the audi, 2 plugs, both 2 pin, one black one red.
    only time mine goes into limp mode is when it overboosted. theres a n75 valve that controls the turbo wastegate and this had packed up. hit 3k rpm and she died. turn off and on and she was good to go . you can test the solonoid by putting 12v to it and it should click. if not, replace it. 60 notes from vw.
  9. Re: What audi engine ?
    Nov 2014
    bournemouth
  10. Re: What audi engine ?
    Nov 2014
    bournemouth
    The engine is slightly facing down at that angle
  1. How To Maximise engine performance audi a4 b5 1.8 20valve engine - non turbo
    By bazz_a4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-04-2018, 11:52 AM
  2. Question Audi A4 3.0 Conv 2004 - Engine whining noise from front of engine.
    By alancobra in forum New Member Introductions
    Last Post: 09-01-2013, 06:10 PM
  3. Question Audi a4 b5 engine swap turbo engine
    By mcgill1 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 14-06-2011, 05:41 PM
  4. Question Knocking sound (inconsistant) on acceleration from engine (1995 Audi Coupe 2.0E - ABK engine)
    By Jonnovision in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 07-11-2010, 07:51 AM
  5. Replies: 0
    Last Post: 22-07-2009, 07:31 PM
