Thread: 1.9 TDI Turbo problem, what to check next?
Results 1 to 10 of 11
  1. 1.9 TDI Turbo problem, what to check next?
    Jun 2009
    Tranby, Norway
    my 2001 1.9 TDI Passat had an intermittent tubo problem, now the car is just a 'DI' because the turbo is not working at all...........
    I took off the rubber inlet hose and checked that the impella spins freely........ it does spin freely.
    Can someone help me out by telling me what things to check next, thanks in advance,
    cheers,
    -John (minus 1 C in the garage today!)
  2. Re: 1.9 TDI Turbo problem, what to check next?
    Aug 2011
    Meath
    A scan might help as it could be the N75 valve has failed. Live data should tell you if the vanes are sticking. VCDS required!
  3. Re: 1.9 TDI Turbo problem, what to check next?
    Jun 2009
    Tranby, Norway
    Quote Originally Posted by Doctle Odd View Post
    Thanks for the quick reply, I had my wife rev the engine a little and the lever on the turbocharger control unit is not moveing at all (is that bad?), might get to the workshop this week. If it get's above 5 degrees in the garage this week I might even have a look at it myself!
    cheers,
    -John
  4. Re: 1.9 TDI Turbo problem, what to check next?
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    As soon as you start the engine the turbo control lever should pull in about 2cm.
    If not, remove the vacuum pipe to the turbo & make sure there is vacuum from the pipe when the engine is running.
  5. Re: 1.9 TDI Turbo problem, what to check next?
    Jun 2009
    Tranby, Norway
    Hi phil, (and thanks)
    when you say "the vacuum pipe to the turbo", do you mean the pipe that goes into the top of the wastegate control unit above th turbo? (just to make sure) I'l have a look tomorrow after work.
    cheers,
    -John
  6. Re: 1.9 TDI Turbo problem, what to check next?
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    Quote Originally Posted by John in Norway View Post
    cheers,
    -John
    Yes, that's the one.
    It doesn't actually have a wastegate.
    The vacuum capsule controls the angle of the variable vanes on the exhaust side of the turbo, which controls the amount of boost from the turbo.
    If you have no vacuum with the engine running, follow the small pipe back to the N75 valve & check if there is any vacuum there.
  7. Re: 1.9 TDI Turbo problem, what to check next?
    Jun 2009
    Tranby, Norway
    Quote Originally Posted by philipharmes View Post
    Thanks mate.........it's -1.5C in the garage this morning I migh wait until saturday afternoon when it's a bit warmer (above zero I hope)!
    cheers,
    -John
  8. Re: 1.9 TDI Turbo problem, what to check next?
    Jun 2009
    Tranby, Norway
    just came in from th cold (-1C), cheked for suction at:
    Turbo control unit hose
    VNT actuator hose
    Hose going into th top of the N75 & where that hose fits on the N75 (next to elecrical plug)
    No suction anywhere........ what's next?
    cheers & thanks for your help
    -John
  9. Re: 1.9 TDI Turbo problem, what to check next?
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    I hope Martin1810 doesn't mind me pushing his site.
    Here is a diagram courtesy of Martin showing the ins & outs of the Passat vacuum setup.
    B5 VACUUM HOSE DIAGRAM - PASSAT
  10. Re: 1.9 TDI Turbo problem, what to check next?
    Check the vacuum hoses they rub through on the stupid plastic engine covers.
  1. 1.9 tdi turbo problem
    By galleon in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 16-09-2010, 05:34 PM
  2. Please Help Turbo problem 2.0 TDI??
    By richya4avant in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 14-04-2010, 10:33 PM
  3. Please Help 2.0 TDi Turbo problem
    By mxb350 in forum Audi A3 - Archive Topics
    Last Post: 11-03-2009, 03:33 PM
  4. Turbo problem 1.9 tdi
    By Angie in forum Chat - Completely Off Topic
    Last Post: 06-12-2007, 06:36 PM
  5. A6 Tdi turbo problem
    By Angie in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 22-10-2006, 07:05 PM
