Thread: Instrument cluster lamp test defective
  1. Instrument cluster lamp test defective
    Oct 2014
    TAUNTON . SOMERSET
    Hi. I got fault code adress17. Instrument cluster
    01298 instrument cluster lamp test 014 defective. So far cluster works fine and looks like light too. Anyone have any experience with it? Thanks
  2. Re: Instrument cluster lamp test defective
    May 2007
    17 Post(s)
    Do you have VCDS or a proper VAG tool? There should be a diagnostic procedure in there somewhere that does a segment test on the cluster. Basically, it switches on each warning light and operates the gauges, etc to let you see if something isn't working. I think that is what you'd need to do to try and diagnose what causing the code.
    Jim.
  3. Re: Instrument cluster lamp test defective
    Oct 2014
    TAUNTON . SOMERSET
    Hi. I got full vcds. Try run output test but its says what required conditions not met. And after that if i try to get in adress17. Istrument cluster its fails and says to many communication errors
  4. Re: Instrument cluster lamp test defective
    Nov 2009
    46 Post(s)
    Which version of VCDS are you using?
  5. Re: Instrument cluster lamp test defective
    Oct 2014
    TAUNTON . SOMERSET
    Latest i gess
  1. Please Help Drivers reversing lamp showing gone on dash but no blown lamp in cluster
    By Dublandy in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 03-12-2011, 06:33 PM
  2. Instrument bulb test
    By Whiskylad in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-07-2011, 10:45 AM
  3. Instrument cluster
    By pricey01 in forum Golf MK5 - 2004 - 2009
    Last Post: 23-01-2011, 08:06 AM
  4. Instrument Cluster
    By Sarge786 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 22-07-2010, 11:26 PM
  5. Instrument cluster
    By TERRYDOO7 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-01-2010, 09:29 PM
