Thread: Flaps
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
  1. Flaps
    Aug 2013
    Embra
    Mud ones.
    Had a browse over at Ebay as one of my mudflaps is loose so I thought I would get a new set.
    Can't work out which ones will fit though, seems to be a lot of "universal" ones pretending to be genuine.
    Anyone got any links to a decent set ? This is for an Avant.
  2. Re: Flaps
    Nov 2012
    Somerset UK
    I think I paid £37 a pair from main dealer, not worth going ebay on these and having to cut etc.
    When you say 'loose' do you mean one of the fixing is loose, if so can't you simply re secure or tighten up?
  3. Re: Flaps
    46 Post(s)
    Buy nothing but genuine.
  4. Re: Flaps
    Aug 2013
    Embra
    Quote Originally Posted by MarkTM View Post
    One is hanging off but not had a chance to look too closely. I don't think they are genuine so a full on set would be useful.
    Anyone know of a supplier of genuine ones online - with my current pre-christmas schedule the chance of getting to Edinburgh Audi is about the same as landing a fridge safely on a comet...
    Maybe a sponsor ?
  5. Re: Flaps
    Jan 2011
    Stafford, UK
    2009 - A6 2.7 TDI (CANA) - S Line - Avant (Multitronic) Daytona Grey.
    Ross-Tech - http://www.ross-tech.com/vcds/tour/main_screen.html
    Screen capture - FastStone Screen Capture - The Best Screen Capture Software
  6. Re: Flaps
    Aug 2013
    Embra
    Bought a set of rears from the above, I will take some photos when I get them.
  7. Re: Flaps
    Jan 2011
    Stafford, UK
    I painted my flaps same as car. Much easier to keep clean than the black plastic.
  8. Re: Flaps
    Nov 2012
    Somerset UK
    Quote Originally Posted by Arragonis View Post
    Won't it look like any other A6 with genuine flaps? Better if you took pics of the old and the new then we can see the diffo betwixt aftermarket and genuine
    Roy, please advise on the process for painting your flaps? What primer did you use and did you do both sides? If easy will look to do the same on mine when the Spring comes!
  9. Re: Flaps
    Jan 2011
    Stafford, UK
    Waste of time doing the side nearest to the tyre, it will only stone chip.
    For the back side :-
    1. First, get the flaps into hot water with washing up liquid in it (like when you do the dishes) and give the flaps a good scrubbing with a scotch pad.
    2. Dry the flaps.
    3. Mask off the tyre side of the flaps
    4. Give the part of the flaps that are to be painted a light spray with Plastic adhesion promoter SPRAYMAX 1K PLASTIC ADHESION PROMOTER 400ML AEROSOL PRIMER SPRAY 680009 | eBay
    5. Next a coat of plastic primer, I used white because that’s the colour of the primer on the car.
    6. Let the primer dry.
    7. Give them a couple of coats of top coat.
    If you have metallic paint you will have to finish off with clear lacquer.
  10. Re: Flaps
    Feb 2014
    Hertfordshire
    I am also thinking about getting these flaps, primarily from the perspective of trying to keep the car cleaner - would you say the flaps help lessen the spray up dirt on the side of the car behind the wheel arches, or this wouldn't be too noticeable? I don't have big issues with stone chips there, but lots of tar spots alway to clean up.. Many thanks..
    2009 A6 Avant (C6) SE 2.0 TDI 136HP multitronic
  1. Flaps anyone?
    By kennyh in forum A7 - S7
    Last Post: 02-11-2012, 12:13 PM
  2. swirl flaps
    By kalem4 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 12-08-2011, 09:07 PM
  3. Mud flaps
    By fat controller in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 16-06-2010, 02:40 PM
  4. Flaps on, or, flaps off.
    By roxyland in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-03-2010, 11:15 PM
  5. How To Mud Flaps
    By harryg in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 15-08-2009, 09:13 AM
