Thread: Post retrofit problems - MFSW & MFD
  1. Post retrofit problems - MFSW & MFD
    Aug 2013
    Evesham
    Hi, starting to bite my nails and pull my hair out..
    I retrofitted a MFSW and MFD to my car, however the airbag light is lit and the MoT is looming.....
    I have attached two scans - one from before the retrofit and the other a recent scan since the retrofit which a local guy has done for me, he's no expert and 'feels out in the cold' with this, he apparently is able to spot faults, but not able to assist with retrofitting.
    So, in attaching the scans, I'm hoping that someone will be able to spot the incompatibilities for me? Hopefully I'll be able to compile a 'shopping list' of the parts I need to fix this and extinguish the airbag light!!!
    My car's an estate with cruise control, the donor parts came from a saloon - so I need to find the correct stalk controls to get back the use of my rear wiper back also, (can someone advise on this too)?
    The donor car's airbag was a single igniter unit, whilst my car's original fit was a dual igniter airbag..
    I've retrofitted the entire stalks, clockspring, ECU assembly from the saloon onto my estate - so regarding the airbag issue, there may be an incompatibility between my car's airbag ECU (mounted on the floor in front of the heater controls, under the dash) and the donor car's clockspring / clockspring stalk ECU/Airbag??
    Can anyone help?
    Best regards
    Jon
    Before retrofit:
    Chassis Type: 3C0
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 72 7D
    VIN: WVWZZZ3CZ6E135807 Mileage: 198390km/123273miles
    01-Engine -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    56-Radio -- Status: OK 0000
    7D-Aux. Heat -- Status: OK 0000
    Address 01: Engine Labels: 03G-906-018-BKP.clb
    Part No SW: 03G 906 018 CD HW: 03G 906 018 CD
    Component: R4 2.0l PPD1.5 G 9627
    Revision: --H05--- Serial number: VWZCZ000000000
    Coding: 0000072
    Shop #: WSC 00450 210 69121
    VCID: 69D3A37D4062C31
    No fault code found.
    Readiness: N/A
    Address 03: ABS Brakes Labels: 3C0-614-095-C2.clb
    Part No SW: 3C0 614 095 Q HW: 3C0 614 095 Q
    Component: ESP 440 C2 H015 0003
    Revision: H015 Serial number: 0658453975
    Coding: 0013602
    Shop #: WSC 05311 000 08193
    VCID: 30650E19A338729
    Address 08: Auto HVAC Labels: 3C0-907-044.lbl
    Part No SW: 3C0 907 044 AA HW: 3C0 907 044 AA
    Component: ClimatronicPQ46 050 0404
    Revision: 00050005 Serial number: 00000000000000
    Shop #: WSC 00000 000 00000
    VCID: 60C5BE59B358829
    Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
    Part No SW: 3C0 937 049 J HW: 3C0 937 049 J
    Component: Bordnetz-SG H37 1301
    Revision: 00H37000 Serial number: 00000005225148
    Coding: E1880F0700041A00000A00000F00000000085D435C0000
    Shop #: WSC 05311 000 00000
    Subsystem 1 - Part No: 3C2 955 119 Labels: 1KX-955-119.CLB
    Component: Wischer VW461 012 0503
    Coding: 00063445
    Shop #: WSC 05311
    Subsystem 2 - Part No: 1K0 955 559 T Labels: 1K0-955-559-AF.CLB
    Component: RegenLichtSens 011 1110
    Coding: 00208933
    Shop #: WSC 05311
    Address 15: Airbags Labels: 3C0-909-605.lbl
    Part No SW: 3C0 909 605 J HW: 3C0 909 605 J
    Component: 05 AIRBAG VW8 029 2521
    Revision: 09029000 Serial number: 003A2PP80KW$
    Coding: 0012341
    VCID: 2D5B176DB40A1F1
    Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
    Part No SW: 3C0 953 549 A HW: 3C0 953 549 A
    Component: Lenksäulenmodul 005 0010
    Revision: 00005000 Serial number: 3C9953507C
    Coding: 0000014
    VCID: 2A511C7185E4089
    Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
    Part No SW: 3C0 920 960 H HW: 3C0 920 960 H
    Component: KOMBIINSTRUMENT VD1 4240
    Revision: X0014000 Serial number: 00000000000000
    Coding: 0007405
    Shop #: WSC 00390 210 90037
    VCID: 2855E6799BE83A9
    Address 19: CAN Gateway Labels: 3C0-907-530.lbl
    Part No SW: 3C0 907 530 C HW: 3C0 907 951 A
    Component: Gateway 007 0040
    Revision: 00007000 Serial number: 0700C05B21152C
    Coding: 3DFD2C04C22003
    Shop #: WSC 00390 210 105809
    VCID: 2143FB5DF8D2CB1
    Address 25: Immobilizer Labels: 3C0-959-433-25.clb
    Part No SW: 3C0 959 433 AB HW: 3C0 959 433 AB
    Component: IMMO 043 0383
    Revision: 00043000 Serial number: VWZCZ000000000
    VCID: 6AD1DC714564C89
    Part No: 3C0 905 861 G
    Component: ELV 027 0380
    3C0905861G ELV 027 0380
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
    Part No: 1K0 959 701 K
    Component: Tuer-SG 024 2366
    Coding: 0000693
    VCID: 36693801415C5C9
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K2 909 144 L
    Component: EPS_ZFLS Kl.069 H07 1806
    VCID: 356B3F0D5C5A571
    Address 46: Central Conv. Labels: 3C0-959-433-46.clb
    Component: KSG PQ46 ELV 043 0472
    Coding: 009000084103087F3F04850540084F0B003C80
    Component: Sounder n.mounted
    Component: NGS n.mounted
    Component: IRUE n.mounted
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
    Part No: 1K0 959 702 K
    Coding: 0000692
    VCID: 377735054656A51
    Address 53: Parking Brake Labels: 3C0-907-801-53.clb
    Part No SW: 3C0 907 801 B HW: 3C0 907 801 B
    Component: EPB VC8HC001 013 0001
    Revision: 013
    Coding: 0000012
    Address 56: Radio Labels: 1K0-035-1xx-56.lbl
    Part No: 1K0 035 186 P
    Component: Radio GR0 015 0019
    Revision: 0001503S Serial number: VWZ2Z2F4320531
    Coding: 0040400
    Shop #: WSC 00028 028 00001
    VCID: 336F0115522E491
    Address 62: Door, Rear Left
    Cannot be reached
    Address 72: Door, Rear Right
    Cannot be reached
    Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
    Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
    Component: PTC-Element 0404
    Revision: 00800000 Serial number:
    After retrofit:
    Chassis Type: 3C0
    Scan: 01 03 08 09 15 16 17 19 25 2E 42 44 46 52 53 56 62 72 77 7D
    VIN: WVWZZZ3CZ6E135807 Mileage: 207390km/128866miles
    15-Airbags -- Status: Malfunction 0010
    25-Immobilizer -- Status: Malfunction 0010
    2E-Media Player 3 -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: Malfunction 0010
    56-Radio -- Status: Malfunction 0010
    77-Telephone -- Status: Not registered 0001
    Coding: 0000072
    Readiness: N/A
    Coding: 0013602
    Shop #: WSC 05311 123 12345
    Coding: 00063445
    Shop #: WSC 05311
    Coding: 00208933
    Shop #: WSC 05311
    Coding: 0012341
    1 Fault Found:
    01587 - Igniter 2 for Airbag; Drivers Side (N250)
    001 - Upper Limit Exceeded - MIL ON
    Part No SW: 3C0 953 549 AE HW: 3C0 953 549 AE
    Component: J0527 0020
    Revision: 00026000 Serial number: 3C5953507AT
    Coding: 0000111
    VCID: 6FE7CD657E862D1
    Part No: XXXXXXXXXXX
    Component: E0221 002 0010
    Part No SW: 3C0 920 971 E HW: 3C0 920 971 E
    Component: KOMBIINSTRUMENT VD1 1216
    Revision: V0002000 Serial number: 00000000000000
    Coding: 0007405
    Shop #: WSC 65536 645 577705
    VCID: 2757E54596F6351
    Part No SW: 3C0 907 530 E HW: 3C0 907 951
    Component: J533__Gateway H10 0080
    Revision: H10 Serial number: 1200P08421060A
    Coding: F9807F160002122003
    VCID: 234FF155E2CED91
    1 Fault Found:
    01044 - Control Module Incorrectly Coded
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 31
    Mileage: 203297 km
    Time Indication: 0
    Date: 2014.04.15
    Time: 12:29:16
    2 Faults Found:
    02823 - Requirements for Locking the Steering Column Lock not met
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 23
    Mileage: 206876 km
    Time Indication: 0
    Date: 2014.08.04
    Time: 20:50:43
    02827 - Wake-Up request via ESP
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 23
    Mileage: 206876 km
    Time Indication: 0
    Date: 2014.08.04
    Time: 20:50:43
    Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
    Part No SW: 5N0 035 342 D HW: 5N0 035 342 D
    Component: SG EXT.PLAYER H13 0150
    Revision: A1001003 Serial number: 7669896880
    Coding: 010000
    Shop #: WSC 05314 000 00000
    VCID: 2855E6795BE83A9
    1 Fault Found:
    03138 - Input AUX IN
    009 - Open or Short to Ground
    Freeze Frame:
    Fault Status: 01101001
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 176
    Mileage: 205687 km
    Time Indication: 0
    Date: 2014.06.22
    Time: 13:40:22
    VCID: 55AB9F8DBC1A771
    Coding: 189000084103087F3F0485054008CF0B003C80
    Coding: 0000692
    1 Fault Found:
    00933 - Electric Window Motor; Passenger Side (V148)
    Revision: 013
    Coding: 0000012
    Address 56: Radio (J0503) Labels: 5M0-035-1xx-56.clb
    Part No SW: 3C8 035 195 G HW: 3C8 035 195 G
    Component: Radio RCD510 050 0207
    Revision: 00000001 Serial number: VWZ1Z3M7086317
    Coding: 04000200020002
    Shop #: WSC 00066 123 12345
    VCID: 2C5D1A694F10169
    2 Faults Found:
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 31
    Mileage: 203297 km
    Time Indication: 0
    Date: 2014.04.15
    Time: 12:29:29
    000 - -
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 31
    Mileage: 203297 km
    Time Indication: 0
    Date: 2014.04.15
    Time: 12:29:24
    Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
    Part No: 3C9 959 703
    Component: Tuer-SG 021 2505
    Coding: 0000144
    VCID: F0E54E19E3B8B29
    Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
    Part No: 3C9 959 704
    Coding: 0000144
    VCID: F1E34B1DE8B2BB1
    Address 77: Telephone Labels: RETROFIT77.lbl
    Part No SW: KTC 364 96P HW: KTC 364 96P
    Component: SWP:3.24.7
    Shop #: WSC 21977 142 74100
    VCID: 3E792021696C949
    End
    2006 PASSAT SPORT ESTATE TDI
    Now with MDI, RCD510, Bluetooth, MFD & MFSW.
  2. Re: Post retrofit problems - MFSW & MFD
    May 2007
    17 Post(s)
    Hi Jon.
    Regarding your airbag problem, your car's airbag ECM is setup for two steering wheel airbag igniters and the donor airbag only has one. So the igniter that is no longer there is shown as open circuit (resistance upper limit exceeded in VW speak).
    I see you've fitted an RCD510 to your car. I'm pretty sure you'll also need to update/replace your Gateway ECU with that radio fitted to prevent battery drain problems.
    I'm no expert at these sorts of retrofits but from what I can see from your scan, you now have a phone on the installation list. Did you take the phone ECU wiring from the donor car too? If not, I'm guessing you will need to recode the installation list in the gateway to remove the phone. That would probably get rid of the gateway incorrect coding DTC.
    You'll probably also need to recode the radio if the phone ECU hasn't been fitted, so that would probably get rid of that incorrect coding DTC too.
    And you'd need to recode the steering elec ECU after you refit the estate stalk switches. As I say, I'm no expert but I think you just need a bit of recoding done.
    Regards.
    Jim
  3. Re: Post retrofit problems - MFSW & MFD
    Aug 2013
    Evesham
    Quote Originally Posted by Flash2 View Post
    Hi Jon.
    Regards.
    Jim
    Hi Jim,
    Changed the Canbus gateway too its an 'E' version, so all's sweet with radio, media in and phone's great - only issue is the airbag light......
    Just a thought but, if I fit an airbac control unit / airbag ECU that matches the single igniter airbag, this should fix the airbag light issue shouldn't it?
    The blown airbag - (I have a replacement) is: 00XE07GWYBJ - 1K0880201BT1QB - 61921051B.
    Can anyone help me to suss out what airbag ECU / control unit number/s I need to look for?? Would be really really grateful
    I'll keep checking the forum just in case anyone can help, or PM me, anything.
    Fingers crossed
    Regards
    Jon
  4. Re: Post retrofit problems - MFSW & MFD
    May 2007
    17 Post(s)
    Hello again Jon.
    You might be able to recode your original airbag ECU to suit the single igniter airbag from the donor car. Failing that, I'm sure replacing your airbag ECU with the one from the donor car would work as long as the rest of the igniters are the same. If there are other differences between the two cars, you could end up with more DTCs than you have now.
    A third option would be to just fit a dummy load into the wiring for the second igniter so the ECU thinks the igniter is still there.
    Jim.
  5. Re: Post retrofit problems - MFSW & MFD
    Aug 2013
    Evesham
    Hello again Jon.
    Jim.
    Hi Jim, thanks again.
    Will let you know how I get on - gotta sort it quite soon now.
    Jon
  1. B6 MFSW & MFD retrofit - small issues
    By Jon928 in forum Retrofits
    Last Post: 30-09-2014, 11:12 PM
  2. MFSW retrofit
    By deci in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 08-01-2014, 06:49 PM
  3. Fitted mfsw and mfd
    By richiemac in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 15-09-2013, 10:16 AM
  4. Please Help Nick King's MFSW, High MFD and Auto Hold Retrofits...
    By ToMBoY_C in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 02-02-2011, 10:23 PM
  5. MFSW with small MFD and radio controls?
    By Turbokiisseli in forum Golf MK5 - 2004 - 2009
    Last Post: 23-01-2011, 08:20 PM
