Thread: Newbie with possible electronic handbrake problem
Results 1 to 10 of 12
  1. Newbie with possible electronic handbrake problem
    Aug 2013
    United Kingdom
    Hi all, I'm a newbie round here but looking for some advice.
    Over the last few weeks, my C7 (manual gearbox) seems to be getting more and more reluctant to engage the handbrake 1st time. When this happens the brake pedal seems to raise up slightly and cannot be depressed. I then have to take my foot completely off the brake and reapply before the handbrake will work. I'm now starting to get really paranoid about this and have to check the dashboard light every time to make sure that the handbrake is actually on (although I always leave the car in gear anyway).
    It's an 80 mile round trip to my dealers and can pretty much guarantee if I took it there it would work absolutely perfectly for them
    Has anyone come across this before?
  2. Re: Newbie with possible electronic handbrake problem
    Jan 2013
    Wessex. and Southern France
    108 Post(s)
    Hi and welcome, my initial thought would be to get it checked regardless. Faults with this system are rare but possible.
  3. Re: Newbie with possible electronic handbrake problem
    Aug 2013
    United Kingdom
    Thanks for your reply. Will give the dealer a ring and try and get it booked in when I'm off work next week. Hopefully (!?) it will replicate the problem there unlike the last time I took and intermittent problem to them
  4. Re: Newbie with possible electronic handbrake problem
    Dec 2009
    Carlisle UK
    Perhaps you could try videoing the problem in order to back up your account when talking to the dealer.
  5. Re: Newbie with possible electronic handbrake problem
    1834 Post(s)
    If it is the switch (which is common) then it may have a "control head" code stored so you could try getting it scanned locally.
  6. Re: Newbie with possible electronic handbrake problem
    Feb 2013
    Northants, UK
    I've had a problem with the electronic handbrake on my manual A6 - see thread here: Electronic handbrake woes
    Based on my experience of how difficult faults with the electronic handbrake appear to be to diagnose, if your car is under warranty just take it to the dealer and get them to fix it now. It will save you a lot of cost and hassle in the long run!
  7. Re: Newbie with possible electronic handbrake problem
    Aug 2013
    United Kingdom
    Thanks all. Will give the dealer a ring tomorrow and get it booked in. Just wondered if it was a known problem as google searches hadn't shown the same issues up. Aero97 - fortunately my issues don't seem as bad as yours were - car is under warranty and hopefully can be sorted quickly.
  8. Re: Newbie with possible electronic handbrake problem
    Feb 2013
    Finland
    13 Post(s)
    For C6/4F there has been a TSB about EPB:
    "DTCs may be stored if the vehicle is driven for a long distance (approximately 620 miles or 1,000 km) without
    using the EPB, parked with hot brakes, and EPB carries out a self-test (calipers opened and closed once). The
    self-test will have different results with hot brakes compared to when the brakes have cooled down. In this event,
    DTCs are stored in the EPB control unit although there is no fault with the system."
    "1. Switch off the ignition.
    2. Restart vehicle.
    3. Move the parking brake switch in both directions (pull to apply parking brake, push to release parking brake).
    4. The EPB malfunction indicator will turn off and the parking brake can again be used normally.
    5. Explain to the customer how to prevent the problem from recurring."
  9. Re: Newbie with possible electronic handbrake problem
    Aug 2013
    United Kingdom
    Update:
    Booked the car in and had to wait a week for an appointment where they had a courtesy car available. During that week the EPB worked perfectly every time, took it to dealer and of course no fault could be found. Not a complete waste of time as I got it serviced at the same time. Next morning, got to work, tried to apply the EPB and it wouldn't work again! The law of sod!!
  10. Re: Newbie with possible electronic handbrake problem
    1834 Post(s)
    That is poor as I am 99.9% sure there would have been a fault code in the EPB memory. Off course the dealer included a full vehicle scan and gave you this with the service sheet didn't they? Just as they are supposed to do and as it says so in the service book, of course they always do this don't they......
  1. Possible Electronic Handbrake problem?
    By Marwil in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 08-04-2013, 10:14 PM
  2. electronic handbrake
    By offaly007 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 21-06-2011, 09:33 PM
  3. Electronic Handbrake
    By Sean Galway in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 06-02-2010, 06:25 PM
  4. Electronic handbrake
    By Petemate in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 04-02-2010, 02:22 PM
  5. Electronic Handbrake Problem
    By a84.0tdi in forum A8 - S8 - V8
    Last Post: 05-10-2008, 09:28 PM
