Thread: Can anyone help
Results 1 to 10 of 11
  1. Can anyone help
    Oct 2014
    Namibia
    Am having this problem with my Audi a3 2004 2.0 fsi. The car struggle or take longer to start 3 or 4 tries and sometimes it may not start and drained the battery, it starts well in the morning or after an hour of cooling.
    It also sounds like a diesel but it's a petrol engine.
    What might be the problem?
  2. Re: Can anyone help
    Southern County Softy
    20 Post(s)
    Scan for faults.
    You could try changing the coolant temperature sensor.
    A4 2.5 tdi QS (mapped)
  3. Re: Can anyone help
    Oct 2014
    Namibia
    Thanks kite
    Is the coolant temperature sensor the same with knock sensor, because someone advice me to buy a knock sensor.
  4. Re: Can anyone help
    46 Post(s)
    Don't buy anything until the car is scanned!!
  5. Re: Can anyone help
    Oct 2014
    Namibia
  6. Re: Can anyone help
    46 Post(s)
    Scan for faults and check your oil level.
  7. Re: Can anyone help
    Oct 2014
    Namibia
    I keep getting this red indicator of engine oil, but the oil is well filled....
    I have scan the car many times, at first it shows lots of faults, but reset it and scan again than the fault disappear. It's even worse now it only start once you put a little bit of petrol on the air outlet, or I don't know what is that part called
  8. Re: Can anyone help
    46 Post(s)
    What was it scanned with? I suggest getting it to a mechanic and don't drive it just in case.
  9. Re: Can anyone help
    Oct 2014
    Namibia
    They scanned it with something looks like a tablet.. But am suspecting it's leaking oil, I don't trust machenics in my area. I have spent olot of money on them already, but the is no solutions
  10. Re: Can anyone help
    46 Post(s)
    You need it scanned with Vw/Audi diagnostic called VCDS or try your local dealer. You need to take the car to a VW/Audi specialist for diagnosis.
