Thread: Flashing glow plug light: High temp bank 1 DPF
  1. Post Flashing glow plug light: High temp bank 1 DPF
    Oct 2014
    Maidenhead
    I have tested the temp sensor bank 1 at the connector, and measures 210 ohms and rises to 350 when the engine is warm.
    The other side of the temp computer measure 5 volts and when shorted is reported with code, which suggests is ok.
    What can cause a high temp bank 1 even when the engine is cold.
    I have cleared the fault but both DPF and glow flashing light come back.
    I have replaced DPF and the sensor PO546, and now run out of ideas.
  2. Re: Flashing glow plug light: High temp bank 1 DPF
    46 Post(s)
    Welcome to VWAF
    Could you tell us the engine? What was the car scanned with, was it VCDS?
  3. Re: Flashing glow plug light: High temp bank 1 DPF
    Oct 2014
    Maidenhead
    Welcome to VWAF
    Thanks for responding
    A4 2007 diesel 2.0 170
    Scanned with a cheapy Autel unit produced code 01350, and then confirmed at the local garage P0546
  1. Please Help dpf flashing glow plug and eng management light on??
    By ahsanx in forum Golf MK5 - 2004 - 2009
    Last Post: 17-01-2019, 09:52 PM
  2. Dpf/glow plug light + engine light audi a3 2.0 tdi
    By Rids in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 17-06-2014, 07:57 PM
  3. DPF/ glow plug light + engine light audi a3 2.0 tdi
    By Rids in forum Chat - Anything with wheels
    Last Post: 16-06-2014, 12:06 PM
  4. Golfgt tdi 170 glow plug light +Dpf light please help!!
    By veedub76 in forum Golf MK5 - 2004 - 2009
    Last Post: 05-01-2013, 10:07 AM
  5. DPF, Flashing Glow Plug and Engine Mang Light on..
    By Imizz in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 25-08-2011, 01:06 PM
