Thread: Help Neede...5340 - Intake Manifold Flap
  1. Help Neede...5340 - Intake Manifold Flap
    Mar 2010
    Galway, Ireland
    My engine management light came on yesterday and after doing a scan there are a couple of errors showing up....Any help would be appreciated.
    VCDS Version: Release 12.12.3 (x64)
    Data version: 20140822
    Monday,20,October,2014,14:18:06:53769
    Chassis Type: 8K (8T0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 47 52 53 56 62 72 77
    VIN: WAUZZZ8KX9A205269Mileage: 173470km/107789miles
    02-Auto Trans -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    10-Park/Steer Assist -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    17-Instruments -- Status: Malfunction 0010
    47-Sound System -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    77-Telephone -- Status: OK 0000
    Address 01: Engine (J623-CAGA)Labels: 03L-906-022-CAG.clb
    Part No SW: 03L 906 022 MKHW: 03L 906 022 B
    Component: R4 2,0L EDCH01 4379
    Revision: 11H01---
    Coding: 0104002C02072118
    Shop #: WSC 00694 210 91850
    ASAM Dataset: EV_ECM20TDI03L906022MK A01006
    ROD: EV_ECM20TDI03L906022C.rod
    VCID: 7AF08555FD0D50CED59-802F
    2 Faults Found:
    5340 - Intake Manifold Flap; Bank 1
    P2008 00 [096] - Electrical Malfunction
    Intermittent - Not Confirmed - Tested Since Memory Clear
    5346 - Intake Manifold Flap; Bank 1
    P2009 00 [175] - Short to Ground
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 13
    Mileage: 173381 km
    Date: 2014.10.19
    Time: 15:34:06
    Readiness: 1 1 0 0 0
    Address 02: Auto Trans (J217)Labels: 0AW-927-156.clb
    Part No SW: 8K0 927 155 AFHW: 0AW 927 156 H
    Component: 0AW 20TDI RdW H01 0006
    Revision: --H01---Serial number: 0000000166
    Coding: 000001
    Shop #: WSC 06325 000 00000
    ASAM Dataset: EV_TCMVL381 A02005
    ROD: EV_TCMVL381.rod
    VCID: 77F69C61CE1F4DA6AA7-8022
    1 Fault Found:
    2225 - RPM Signal from ECU
    P0727 00 [032] - No Signal
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 0
    Fault Frequency: 0
    Reset counter: 0
    Mileage: 0 km
    Date: 2000.00.00
    Time: 00:00:00
    Address 03: ABS Brakes (J104)Labels: 8K0-907-379.clb
    Part No SW: 8K0 907 379 AEHW: 8K0 907 379 AE
    Component: ESP8 frontH04 0240
    Revision: --------Serial number: --------------
    Coding: 170500
    VCID: 7CFC834DFF396EFEC75-8029
    No fault code found.
    Address 05: Acc/Start Auth. (J393)Labels: 8K0-907-064-05.clb
    Part No SW: 8K0 907 064 CHW: 8K0 907 064 C
    Component: BCM2 1.1H80 0145
    Revision: 00002001
    Coding: 011100
    VCID: 3064677D63F15A9E2BD-8065
    Subsystem 1 - Part No SW: 8T0 959 754 DHW: 8T0 959 754 D
    Component: FBSAUDIB8 IDGH37 0060
    Subsystem 2 - Part No SW: 8K0 905 852 DHW: 8K0 905 852 D
    Component: ELVAUDIB8H36 0041
    Address 08: Auto HVAC (J255)Labels: Redir Fail!
    Part No SW: 8T2 820 043 SHW: 8T2 820 043 S
    Component: KLIMA 3 ZONEN H06 0150
    Revision: D0000000Serial number: 01040220091437
    Coding: 34040000
    VCID: 42803DB5DD5DD80ECD9-8017
    Address 09: Cent. Elect. (J519)Labels: 8K0-907-063.clb
    Part No SW: 8K0 907 063HW: 8K0 907 063
    Component: BCM1 1.0H22 0253
    Revision: 01022001Serial number: 00000000197652
    Coding: 6900C0B10034A7000001000000005F5F001D42080000014100 0000
    VCID: ECDC330D0F597E7ED75-80B9
    Subsystem 1 - Part No SW: 8K2 955 119 AHW: 8T2 955 119Labels: 1KX-955-119.CLB
    Component: WWS 020209H05 0070
    Coding: 00FD11
    Subsystem 2 - Part No SW: 8K0 955 559HW: 8K0 955 559Labels: 8K0-955-559.CLB
    Component: RLSH04 0003
    Coding: 025028
    Subsystem 3 - Part No SW: 8K0 941 531 AAHW: 8K0 941 531 AA
    Component: E1 - LDSH07 0080
    Address 10: Park/Steer Assist (J446)Labels: 8K0-919-475.clb
    Part No SW: 8K0 919 475 FHW: 8K0 919 475
    Component: PARKHILFE 4KH06 0040
    Revision: 11001001Serial number: 40140904100379
    Coding: 000103
    VCID: 3C7C434DBFB9AEFE875-8069
    1 Fault Found:
    02070 - Rear Parking Aid Sensors
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 210
    Mileage: 158451 km
    Time Indication: 0
    Date: 2014.05.10
    Time: 12:57:06
    Freeze Frame:
    Temperature: 17.0°C
    Address 15: Airbags (J234)Labels: 8K0-959-655.clb
    Part No SW: 8K0 959 655 BHW: 8K0 959 655 B
    Component: AirbagVW-AU10 H27 0410
    Serial number: 0038JD1E1YLS
    Coding: 30363435363030303030554A3052384B3053
    ASAM Dataset: EV_AirbaECUVWAUDI010 A02007
    ROD: EV_AirbaECUVWAUDI010_AU48.rod
    VCID: 3C7C434DB7B9AEFE875-8069
    Crash sensor for side airbag; driver side:
    Serial number: 6334MSME450346140
    Crash sensor for side airbag; passenger side:
    Serial number: 6344MSME45754578J
    Crash sensor for side airbag; rear driver side:
    Serial number: 6352QSME121C0102$
    Crash sensor for side airbag; rear passenger side:
    Serial number: 6362QSME46214B26E
    Crash sensor for front airbag; driver side:
    Serial number: 63732SME511B1E3C4
    Crash sensor for front airbag; passenger side:
    Serial number: 63832SME641B1902Y
    Address 16: Steering wheel (J527)Labels: 8K0-953-568.clb
    Part No SW: 8K0 953 568 FHW: 8K0 953 568 F
    Component: Lenks.ModulH15 0013
    Revision: --------Serial number: 90304IB40008X
    Coding: 000016
    VCID: 3D7A4E49A4A3A7F6B0B-8068
    Component: E221 - MFLH02 0003
    Address 17: Instruments (J285)Labels: 8T0-920-xxx-17.clb
    Part No SW: 8K0 920 980 BHW: 8K0 920 980 B
    Component: KOMBIINSTR.H18 0224
    Revision: 00200000Serial number: 9E363R929
    Coding: 031F080002002600010000
    VCID: 3162627968FB5396243-8064
    1 Fault Found:
    00003 - Control Module
    005 - No or Incorrect Basic Setting / Adaptation
    Freeze Frame:
    Fault Status: 01100101
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 210
    Mileage: 158451 km
    Time Indication: 0
    Date: 2014.05.10
    Time: 12:48:03
    Address 19: CAN Gateway (J533)Labels: 8T0-907-468.clb
    Part No SW: 8T0 907 468 MHW: 8T0 907 468 H
    Component: GW-BEM 5CANH06 0095
    Revision: GB300043Serial number: 4300G0912801E4
    Coding: 000303
    VCID: 4B9E1091EA1719463EF-801E
    Subsystem 1 - Part No SW: 8K0 915 181 BHW: 8K0 915 181 B
    Component: J367-BDMH04 0150
    Address 42: Door Elect, Driver (J386)Labels: 8K0-959-793.clb
    Part No SW: 8K0 959 793 EHW: 8K0 959 793 E
    Component: TSG FAH11 0250
    Revision:Serial number: 0000008466220
    Coding: 011002204001410001
    Address 46: Central Conv. (J393)Labels: 8K0-907-064-46.clb
    Revision: 00002001Serial number: 0116716740
    Coding: 011F062200390400012001
    Subsystem 1 - Part No: 8K0 951 177
    Component: DWA-SensorH02 0040
    Subsystem 2 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HOH03 1301
    3 Faults Found:
    01518 - Bulb for Back-Up Lights; Left (M16)
    012 - Electrical Fault in Circuit - MIL ON
    Freeze Frame:
    Fault Status: 11101100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 210
    Mileage: 158451 km
    Time Indication: 0
    Date: 2014.05.10
    Time: 12:48:01
    02615 - Fuel Tank Cap; Lock
    009 - Open or Short to Ground
    Freeze Frame:
    Fault Status: 01101001
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 210
    Mileage: 158461 km
    Time Indication: 0
    Date: 2014.05.10
    Time: 13:37:35
    02616 - Fuel Tank Cap; Unlock
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 10
    Mileage: 158461 km
    Time Indication: 0
    Date: 2014.05.10
    Time: 13:49:59
    Address 47: Sound System (J525)Labels: 8T0-035-223-ASC.clb
    Part No SW: 8T0 035 223 ABHW: 8T0 035 223
    Component: DSP STDH07 0220
    Revision: S2100000
    Coding: 0203010102
    VCID: 6ED8B905B9450C6E791-803B
    Address 52: Door Elect, Pass. (J387)Labels: 8K0-959-792.clb
    Part No SW: 8K0 959 792 EHW: 8K0 959 792 E
    Component: TSG BFH11 0250
    Revision:Serial number: 0000008435326
    Coding: 011002204401410001
    Shop #: WSC 06325 123 12345
    VCID: 418232B9D85BC316D43-8014
    Address 53: Parking Brake (J540)Labels: 8K0-907-801-V1.clb
    Part No SW: 8K0 907 801 GHW: 8K0 907 801 G
    Component: EPB Audi B8H08 0080
    Revision: 00000003Serial number: 10000000177261
    Shop #: WSC 00000 000 00000
    VCID: 336E687192E7618656F-8066
    Address 56: Radio (J503)Labels: 8Tx-035-1xx-56.clb
    Part No SW: 8T2 035 186 PHW: 8T2 035 186 P
    Component: Concert3H01 0300
    Revision: 00000003Serial number: AUZ5Z6I1176957
    Coding: 0502008201018D00437B070900
    VCID: 458A26A9CC73EF36E8B-8010
    Subsystem 1 - Part No SW: 8T0 919 603 EHW: 8T0 919 603 E
    Component: Display
    1 Fault Found:
    03157 - Functionality limited due to Communications Disruption
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 6
    Fault Frequency: 254
    Reset counter: 138
    Mileage: 158451 km
    Time Indication: 0
    Date: 2014.05.10
    Time: 12:48:02
    Freeze Frame:
    Bin. Bits: 10000000
    Bin. Bits: 00000000
    Bin. Bits: 00000000
    Bin. Bits: 00000000
    Bin. Bits: 00000000
    Bin. Bits: 10000000
    Bin. Bits: 00000000
    Bin. Bits: 00000000
    Address 62: Door, Rear Left (J388)Labels: 4F0-959-795.clb
    Part No SW: 4F0 959 795 NHW: 8K0 959 795 C
    Component: TSG HLH10 0251
    Revision:Serial number: 0000008434141
    Coding: 010002204001210001
    VCID: 448C3BADC749D63EFF5-8011
    Address 72: Door, Rear Right (J389)Labels: 4F0-959-795.clb
    Component: TSG HRH10 0251
    Revision:Serial number: 0000008434161
    Address 77: TelephoneLabels: 8P0-862-335.lbl
    Part No SW: 8T0 862 335 DHW: 8T0 862 335 C
    Component: FSE_256x BTH33 0600
    Revision: 00000000Serial number: 00000005057525
    Coding: 0010320
    VCID: 3B7E40517AB7A9C68EF-806E
    End---------------------------------------------------------------------
    '09 A4 SE 143hp Multitronic - Quartz Grey
  2. Re: Help Neede...5340 - Intake Manifold Flap
    Jan 2009
    Kidderminster
    Bank 1 is the one on the drivers side (UK), it looks like an issue with the swirl flap motor.
    When you turn on the ignition the motor should cycle through about 90 degrees, moving the rod that connects to the intake swirl flap, and when you accelerate the motor opens and closes the flap accordingly. Does your motor move?
  3. Re: Help Neede...5340 - Intake Manifold Flap
    Mar 2010
    Galway, Ireland
    Apologies for the late, late response... this issue seemed to have been a 'glitch' and it resolved itself. Fingers crossed it remains that way but, if not, I can check this.
    Thanks for your help though!
  1. possible faulty intake manifold flap.
    By rocket1 in forum Touran - Sharan - Caravelle
    Last Post: 10-05-2014, 07:53 PM
  2. Intake manifold flap
    By john-mandy in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 20-12-2010, 11:48 PM
  3. Intake Manifold Flap (V157)
    By SebastianTDI140 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 15-06-2010, 08:07 PM
  4. Motor for intake manifold flap
    By stephen k in forum Golf MK4 - 1999 - 2004
    Last Post: 31-05-2009, 05:47 PM
  5. Motor Intake Manifold Flap
    By daveaustin in forum Archive posts
    Last Post: 06-12-2007, 04:39 PM
