Thread: 2007 S3 8P - P0441 and 01089 errors
  1. 2007 S3 8P - P0441 and 01089 errors
    I know this comes up a lot but this error is ruining this car for me. I have it 5 months and the engine light has been on basically since I bought it.
    I have an OBD2 VAG scanner. When I connect using the standard com I get the following errors: P0441 1/2 & P0441 2/2 EVAP Emission Control System Purge Flow Fault
    When I connect for the same error using VAG diagnostics I get the error code: 01089 Switch for Tensioning Strut Stowed (F204). sporadic 002-Lower
    I have replaced the purge valve and the pipes either side and the fuel tank breather valve. Is the real error 01089? Why doesn't vag mention anything about the P0441 errors?
    Does anyone know anyone good for this in Dublin? I have tried 3 garages that claim to be good for this stuff and were terrible. I was going to try a charcol canister I keep reading about next. I dont know where this is in the car or how to check it.
    Would appreciate any info you have.
    Thanks!!
  2. Re: 2007 S3 8P - P0441 and 01089 errors
    Oct 2010
    rainham kent
    I had this code on my car and although it never produced the dash light (due to not reoccurring enough times) but I took it back to main dealer during its warranty period and they replaced the charcoal canister and cleaned the throttle valve... Since then no fault at all. No idea on cost though as was under warranty
  1. Error codes P0441 and P0171
    By callmegoose in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 18-09-2014, 02:29 PM
  2. p0441 advise please
    By roy2001 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 28-11-2013, 10:50 PM
  3. Please Help P0441 fuel evaporation system flow rate faulty
    By audiyoudo in forum Golf MK5 - 2004 - 2009
    Last Post: 14-02-2010, 06:56 PM
  4. HVAC to many errors???
    By Shaka1976 in forum VCDS - Help Requests
    Last Post: 02-05-2009, 04:41 PM
  5. P0343 and P0441
    By mike20255 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-01-2008, 02:26 AM
