Thread: 1.8 t Engine cheating/jumping when accelerating
  1. 1.8 t Engine cheating/jumping when accelerating
    Dec 2013
    Arendal, Norway
    Car: 1998 A6 1.8t
    When accalerating, some times the engine is running 100% smooth. But maybe 40 % of the time, it will cheat/spit and making the acceleration really rough.
    Spark plugs are changed. No difference. Are there any common problems with this engine causing this? Since its not all the time, what could cause this problem?
    2012 VW Passat Variant 4motion
    Engine: 2.0 TDI (170 hp)
    Gearbox: DSG
  2. Re: 1.8 t Engine cheating/jumping when accelerating
    Oct 2014
    East London, UK
    I would check the engine mounts. As this was my issue with an A3 a few years back. Found out one of the Engine Mounts (Rubber Mount) were broken. Hope this helps.
  3. Re: 1.8 t Engine cheating/jumping when accelerating
    Apr 2009
    Other things to try are cleaning the MAF, clean out the throttle body (making sure you clean the edges of the butterfly valve too) and the sensor bolted into this. And I have rotated the throttle body through 90 degrees to make the air passage smoother. Its not any worse, but it's worth a try!
  1. Audi a3 53 reg 2.0 fsi jumping/jerking when accelerating??
    By Emmafrost in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 01-12-2013, 04:16 PM
  2. Engine rpm fluctuating/jumping at idle
    By A4flyer in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-04-2013, 08:04 PM
  3. Audi a3 bkd rough idling and engine jumping!!!!! HELP
    By Optimus Prime in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 08-08-2012, 10:05 AM
  4. 1.9 tdi engine was flat accelerating
    By celticyorkie in forum Alhambra
    Last Post: 20-11-2010, 06:31 PM
  5. golf GT TDI AHF engine RPM jumping
    By dreamworx in forum Golf MK4 - 1999 - 2004
    Last Post: 02-01-2008, 01:16 PM
