Need to take the sump of the lupo because of flashing oil light for 2 years now.
I very much doubt it's pickup needs cleaning as no strange noises oil getting to the top, but think it's worth checking.
When checking the bolts, there are 2-3 hidden behind a plate where the flywheel is
on the flywheel there are two notches, so you can put the ball-ended allen key there, but the problem is they are not lined up. Do i line these up turning the engine manually with a ratchet?
