Thread: A6 3tdi Quattro Parking brake problem
Page 1 of 3 123 LastLast
Results 1 to 10 of 24
  1. A6 3tdi Quattro Parking brake problem
    My 2006 a6 has had a parking brake problem (vcds posted below), initially it was intermittent, I got the yellow symbol and parking brake malfunction, I used vcds to scan and try to clear the faults, but the same fault from the same date would not clear, it kept coming back (but with the same data and time), but now the red p symbol in the speedo keeps flashing and the dis show parking brake under diagnosis and i cannot turn it off (even though vcds is not connected), i have tried pulling the parking brake fuses but to no avail, I know the light in my brake switch is out, so ignore that, is the controller goosed or is it the motors/wiring?
    Monday,22,September,2014,17:42:09:15531
    VCDS -- Windows Based VAG/VAS Emulator
    VCDS Version: 12.12.3.0 (x64)
    Data version: 20140822
    VIN: License Plate:
    Mileage: 206320km-128201mi Repair Order:
    Chassis Type: 4F0
    Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 37 42 46 47 4F 52 53 55
    56 61 62 72 76 77
    Mileage: 206320km/128201miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    07-Control Head -- Status: OK 0000
    0E-Media Player 1 -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    37-Navigation -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    53-Parking Brake -- Status: Malfunction 0010
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    61-Battery Regul. -- Status: OK 0000
    76-Park Assist -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine Labels: 059-907-401-ASB.clb
    Part No SW: 4F0 910 401 F HW: 4F0 907 401 A
    Component: 3.0L V6TDI G000AG 0030
    Revision: --H01--- Serial number:
    Coding: 0011772
    Shop #: WSC 66565 257 00032
    VCID: 1F460073CE8177E6827-804A
    4 Faults Found:
    19804 - Control Circuit for Controller for Turbocharger 1 (J724)
    P3348 - 005 - Electrical Malfunction
    Freeze Frame:
    RPM: 756 /min
    Torque: 70.2 Nm
    Speed: 0.0 km/h
    Temperature: 61.2°C
    Voltage: 13.00 V
    Voltage: 13.00 V
    Duty Cycle: 88.8 %
    Duty Cycle: 50.1 %
    16785 - EGR System
    P0401 - 001 - Insufficient Flow
    Freeze Frame:
    RPM: 1638 /min
    Torque: 54.6 Nm
    Speed: 53.8 km/h
    Duty Cycle: 70.7 %
    Duty Cycle: 20.9 %
    Mass Air / Rev.: 387.8 mg/str
    Duty Cycle: 70.6 %
    Mass Air / Rev.: 217.4 mg/str
    29703 - Please check Fault Memory in Battery Monitoring Module
    U1007 - 001 - - Intermittent
    Freeze Frame:
    RPM: 1176 /min
    Torque: 42.9 Nm
    Speed: 41.4 km/h
    (no units): 1198.5
    Voltage: 13.83 V
    Temperature: 21.6°C
    (no units): 4.0
    Torque: 226.2 Nm
    18061 - Please check DTC Memory of ABS Controller
    P1653 - 002 -
    Freeze Frame:
    RPM: 1050 /min
    Torque: 39.0 Nm
    Speed: 41.4 km/h
    Duty Cycle: 1.0 %
    Voltage: 13.91 V
    Bin. Bits: 00101001
    Torque: 288.6 Nm
    Temperature: 41.4°C
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans Labels: 09L-927-760.lbl
    Part No SW: 4F0 910 156 H HW: 09L 927 156
    Component: AG6 09L 3.0lTDI RdW 0110
    Revision: 00000001 Serial number: 0019503
    Coding: 0000001
    Shop #: WSC 00006 210 89785
    VCID: 28541BAF9BCFB05EF3D-807D
    No fault code found.
    Address 03: ABS Brakes Labels: 4F0-910-517.lbl
    Part No SW: 4F0 910 517 A HW: 4F0 614 517 A
    Component: ESP8 quattro H03 0330
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0004488
    Shop #: WSC 02335 785 00200
    VCID: 22400987FDF35A0EAD9-8077
    1 Fault Found:
    00473 - Control Module for Elect. Park/Hand Brake (J540)
    008 - Implausible Signal
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 178
    Mileage: 206327 km
    Time Indication: 0
    Date: 2014.09.22
    Time: 17:33:33
    Freeze Frame:
    Hex Value: 0x0280
    Hex Value: 0x40A2
    Hex Value: 0x0000
    Hex Value: 0x00AA
    Hex Value: 0x00FF
    Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
    Part No SW: 4F0 910 852 HW: 4F0 905 852 B
    Component: FBSAUDIC6 ELV H30 0220
    Revision: 31050601 Serial number: 10600200021071
    Coding: 0000023
    Shop #: WSC 00762 210 91708
    VCID: E3CECC832269930666F-80B6
    Subsystem 1 - Part No: 4F0 910 131 G
    Component: FBSAUDIC6 EZS H43 0060
    Subsystem 2 - Part No: 4F0 910 335
    Component: FBSAUDIC6 KSG H25 0060
    Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
    Part No SW: 4F1 910 732 D HW: 4E0 035 729
    Component: Interfacebox H43 5570
    Revision: 00000000 Serial number: 350DA047510324
    Coding: 0000002
    VCID: 254A129BECDDAD36C8B-8070
    Subsystem 1 - Part No: 4F0 910 609
    Component: Bedienteil MMIC6H03 0870
    Subsystem 2 - Serial number: 00000000007081
    Subsystem 3 - Serial number: 0108.04.040000000100010002’
    Subsystem 4 - Serial number: 010002’
    Address 08: Auto HVAC Labels: 4F0-910-043.lbl
    Part No SW: 4F0 910 043 HW: 4F2 820 043 C
    Component: KLIMABETAETIGUNGH11 0060
    Revision: 00000021 Serial number: 00000000016249
    Coding: 0009238
    VCID: DBBEF4631A19ABC62EF-808E
    Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
    Part No SW: 4F0 910 279 HW: 4F0 907 279
    Component: ILM Fahrer H14 0080
    Revision: 00000000 Serial number: 4F0907279
    Coding: 0012121
    VCID: E6C8D597D15BE62E811-80B3
    Subsystem 1 - Part No: 4F2 910 113 Labels: 1KX-955-119.CLB
    Component: Wischer AudiC6 H04 0150
    Coding: 00062736
    Shop #: WSC 02335
    Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
    Component: REGENLICHTSENSORH10 0040
    Coding: 00141886
    Shop #: WSC 02335
    Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
    Part No SW: 4E0 910 111 F HW: 4E0 035 111
    Component: CD-Changer H43 0470
    Revision: 00000000 Serial number: AUZ5ZBD2005499
    Shop #: WSC 00000 000 00000
    VCID: 1C3C377FDF976CFE675-8049
    Address 15: Airbags Labels: 4F0-910-655-8R.lbl
    Part No SW: 4F0 910 655 G HW: 4F0 959 655
    Component: 20 AIRBAG AUDI8RH24 0110
    Revision: 07H24000 Serial number: 00358D058E6J
    Coding: 0012848
    Shop #: WSC 00762 210 83614
    VCID: 2B5EE4A38A399B461EF-807E
    Subsystem 1 - Serial number: 6332CSME0261376A$
    Subsystem 2 - Serial number: 6342CSME027C7659A
    Subsystem 3 - Serial number: 6351HSME02191329.
    Subsystem 4 - Serial number: 6361HSME02190E1E9
    Subsystem 5 - Serial number: 6371VSME021745002
    Subsystem 6 - Serial number: 6381VSME02320A539
    Address 16: Steering wheel Labels: 4F0-910-549.lbl
    Part No SW: 4F0 910 549 HW: 4F0 953 549 A
    Component: Lenksäulenmodul H06 0130
    Revision: 00H06000 Serial number: 90025041200216
    Coding: 0102141
    Subsystem 1 - Part No: XXXXXXXXXXX
    Component: Lenkradmodul H04 0080
    Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
    Part No SW: 4F0 910 900 A HW: 4F0 920 950 H
    Component: KOMBIINSTR. M73 H07 0460
    Revision: 00600000 Serial number: 49F313K44
    Coding: 0001443
    Shop #: WSC 54064 067 57207
    VCID: 1E383D77C98B7EEE891-804B
    Address 19: CAN Gateway Labels: 4F0-910-468.lbl
    Part No SW: 4F0 910 468 A HW: 4F0 907 468 B
    Component: Gateway H09 0030
    Revision: 09 Serial number: 08008044230254
    Coding: ECFE73C41B3104
    VCID: 2756189396D1BF26FA7-8072
    Address 37: Navigation Labels: 4E0-910-88x-37.lbl
    Part No SW: 4E0 910 887 D HW: 4E0 919 887 C
    Component: MNS ECE H43 0550
    Revision: 00000000 Serial number: 353DP047515556
    VCID: 2E58EDB7B92BEE6E391-807B
    Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
    Part No SW: 4F0 910 793 B HW: 4F0 959 793 B
    Component: TSG FA H10 0020
    Revision: 00000000 Serial number: „
    Coding: 0017018
    VCID: 29521EAB80C58956EC3-807C
    Address 46: Central Conv. Labels: 4F0-910-289.lbl
    Part No SW: 4F0 910 289 E HW: 4F0 907 289 E
    Component: Komfortgeraet H14 0090
    Revision: 00900014 Serial number: 01000172500000
    Coding: 0142835
    VCID: 2C5CE7BF8F379C7E175-8079
    Subsystem 1 - Part No: 1K0 951 605 A
    Component: LIN BACKUP HORN H01 1201
    Subsystem 2 - Part No: 4F0 910 177
    Component: Innenraumueberw.H01 0010
    Address 47: Sound System Labels: 4F0-910-223-AS.lbl
    Part No SW: 4F0 910 223 G HW: 4F0 035 223
    Component: Amp.-ASK H09 0350
    Revision: 00000001 Serial number: 02904040009669
    Coding: 0000003
    Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
    Part No SW: 4F0 910 280 HW: 4F0 907 280 A
    Component: ILM Beifahrer H07 0040
    Revision: Serial number: 00000000008460
    Coding: 0001103
    VCID: DEB8FD77090BBEEE491-808B
    Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
    Part No SW: 4F0 910 793 B HW: 4F0 959 792 B
    Component: TSG BF H10 0020
    Revision: 00000000 Serial number: 2Y
    Coding: 0017018
    Address 53: Parking Brake Labels: 4F0-910-801.clb
    Part No SW: 4F0 910 801 HW: 4F0 907 801
    Component: EPB C43HC002 H03 0020
    Revision: C43HC002
    Coding: 0000321
    Shop #: WSC 02334 785 00200
    VCID: DDBAFA7B040DA5F650B-8088
    2 Faults Found:
    02432 - Supply Voltage for Left Parking Brake Motor (V282)
    011 - Open Circuit - MIL ON
    Freeze Frame:
    Fault Status: 11101011
    Fault Priority: 2
    Fault Frequency: 42
    Reset counter: 169
    Mileage: 205128 km
    Time Indication: 0
    Date: 2014.09.04
    Time: 07:15:30
    Freeze Frame:
    Voltage: 9.94 V
    Count: 116
    02442 - Function Lamp in Control Head
    009 - Open or Short to Ground
    Freeze Frame:
    Fault Status: 01101001
    Fault Priority: 6
    Fault Frequency: 254
    Reset counter: 178
    Mileage: 184112 km
    Time Indication: 0
    Date: 2013.04.19
    Time: 10:50:31
    Freeze Frame:
    Voltage: 10.04 V
    Count: 65
    Address 55: Xenon Range Labels: 8P0-907-357.lbl
    Part No: 8P0 907 357 A
    Component: Dynamische LWR H01 0010
    Coding: 0000003
    Shop #: WSC 02327 785 00200
    VCID: 3874CBEF4B6F20DE63D-806D
    Address 56: Radio Labels: 4E0-910-541.lbl
    Part No SW: 4E0 910 541 T HW: 4F0 035 541
    Component: TUNER EU/US/RDW H41 0630
    Revision: 00000000 Serial number: 352DI047520680
    Coding: 0000001
    VCID: 3162F6CBA815F196243-FFFF
    Address 61: Battery Regul. Labels: 4F0-910-181.lbl
    Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
    Component: ENERGIEMANAGER H11 0490
    Revision: 00000000 Serial number: 00000000009239
    Shop #: WSC 00000 640 00290
    VCID: 234E0C83E2E95306A6F-8076
    Subsystem 1 - Part No: 009 151 05A K
    Component: von VA0 0404210083
    Coding: 3030393135313035414B2056413030343034323130303833
    Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
    Part No SW: 4F0 910 795 A HW: 4F0 959 795 A
    Component: TSG HL H09 0010
    Coding: 0016426
    VCID: 2A50E1A785C3824EE59-807F
    Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
    Part No SW: 4F0 910 795 A HW: 4F0 959 794 A
    Component: TSG HR H09 0010
    Coding: 0016426
    Address 76: Park Assist Labels: 4Fx-910-283.lbl
    Part No SW: 4F0 910 283 HW: 4F0 919 283
    Component: Parkhilfe 4-Kan H09 0020
    Revision: --.--.-- Serial number: 11730410104003
    Coding: 0001006
    VCID: E1C2C68B38758116743-80B4
    Address 77: Telephone Labels: 4E0-910-333.lbl
    Part No SW: 4E0 910 333 F HW: 4E0 862 333 C
    Component: TELEFONMODUL EU 0770
    Revision: 00000003 Serial number: T2AUDX0307H326
    Coding: 0000006
  2. Re: A6 3tdi Quattro Parking brake problem
    Jul 2013
    76 Post(s)
    Check the plug to the left hand rear caliper just incase its become damaged.
    There was someone recently who had this sort of fault just search through the previous posts to find it.
    Here you go https://www.vwaudiforum.co.uk/forum/s...ar-Brakes-Help
    Dan
    2009/2010 2.0 TDIe SE
    1 1 0
  3. Re: A6 3tdi Quattro Parking brake problem
    Nov 2012
    Somerset UK
    What age is your battery and have you tested it?
    Ask as from my experience ABS and EPB react first when a battery is faulty.
  4. Re: A6 3tdi Quattro Parking brake problem
    Quote Originally Posted by MarkTM View Post
    The battery is original, have had no warnings or faults in the log, but will check and charge/replace if necessary, my worry is that the brake was working even though there was a fault before (only a warning in the dis) but now it does not work at all and i have a permanent flashing "P" symbol in the speedo, is the EPB control module goosed? is there any way to test it at the connector end at the brake?
    I saw a thread here saying the flashing P symbol can be as a result of a wrong vag com scan http://www.justanswer.com/audi/7miii...attro-3-2.html. If so, how do i stop this?
    I plan to look at connector on brake and strip/replace wire if necessary, is there any test i can do to see if the EPB module is outputting correct voltage here (with a voltmeter?)
  5. Re: A6 3tdi Quattro Parking brake problem
    Sep 2011
    Lurking over a keyboard ...
    Quote Originally Posted by singhl View Post
    The battery is original, have had no warnings or faults in the log, ...
    Check state of charge of battery in module 61, access MVB 06 data window 3 will have SOC value.
    ... is the EPB control module goosed?
    Doesn't seem it as you probably would have got a control module defective DTC or something of that nature.
    You may find this list of MVB's handy to view inside EPB module, Link:- http://www.audi-portal.com/en/diagno...u_12687.html#1
    Yes and as there's only 2 wires no chance of getting wrong one, pin 1 is + and pin 2 is -
  6. Re: A6 3tdi Quattro Parking brake problem
    Aug 2013
    Southampton UK
    Interested to understand if you get this fixed as I have same.
    The amber warning was intermittent but is now continuous
    On the odd occasion the brake doesnt release until the car is stwitched off at the ignition and locked/unlocked
  7. Re: A6 3tdi Quattro Parking brake problem
    Quote Originally Posted by gupsterg View Post
    Many thanks for that info I will have to wait till weekend to try this.
  8. A6 3tdi Quattro Parking brake problem
    Oct 2012
    Stockton on Tees
    I had a similar issue a few months back, can you close and open the park brake with VCDS? My park brake switch had failed so that was all that needed to be changed.
  9. Re: A6 3tdi Quattro Parking brake problem
    Aug 2013
    Southampton UK
    I can open and close the park brake with the switch actually no problem, not tried with the diagnosis software, I don't have it
    It just throws an error all the time
  10. Re: A6 3tdi Quattro Parking brake problem
    Took connector off - peeled back the sleeving and one wire was cleaned snapped off due to corrosion, i have put a volmeter across the snapped with and other, onyl getting 0v, should it be >12V or something else, maybe the wire is corroded further down the line once i get it fixed, is there any adaption or procedure i need to do in vcds?
  1. Please Help Electronic Parking Brake Problem
    By Conehead in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 16-07-2014, 04:43 PM
  2. A6 C6 3.0 TDI Quattro - ESP - Yaw Sensor - Parking Brake
    By superdyke990 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 25-11-2013, 10:29 PM
  3. Please Help Parking brake problem - please help
    By spako in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 14-01-2013, 10:34 AM
  4. C6 3.0 TDi Quattro Parking Brake
    By mattyn in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 04-06-2012, 09:04 PM
  5. Please Help B6 Electric Parking Brake - Big Problem
    By moodyshak in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 18-02-2010, 08:34 AM
