Thread: Pressure sensor for brake boost failure
  1. Pressure sensor for brake boost failure
    Jun 2014
    Oslo, norway
    Hi guys,
    Seems this forum is friendly and has a lot of knowledge, im new so take it easy on me
    So I have had this fault code for over a year now, i have deleted the code, but code comes up right away when clearing it. I have googled "brake pressure sensor audi a3 1.6 fsi" and looked for picture on how the sensor lookes like, so I can diagnose physicly on the sensor..But seems like I only find the MAP sensor... Can someone please help me on where I can find the sensor? Picutre is indeed helpfull. Oh, and my ride is an Audi A3 1.6 FSI 53 plate FWD..
    Maybe this will clear my rear break caliper issue if fixed
    Thanks guys
  2. Re: Pressure sensor for brake boost failure
    May 2007
    knee deep in clunge
    14 Post(s)
    g294 is part of servo pipe and can be replaced on its own
  3. Re: Pressure sensor for brake boost failure
    Jun 2014
    Oslo, norway
    Is this the part i need to replace?
    I know where this is located under the bonnet. But searching the part number gives me MAP sensor. Can you confirm this by any chance?
  4. Re: Pressure sensor for brake boost failure
    May 2007
    knee deep in clunge
    14 Post(s)
    thats the bugger, etka describes it as a map sensor so purchase it and fit the blighter to see if it resolves the fault
  5. Re: Pressure sensor for brake boost failure
    Jun 2014
    Oslo, norway
    Not the most expensive part. Could try.
    Earlier today, i checked this sensor, turns out there was a snapped wire and some corrosion build up. Gotta get me wire strippers
  1. Please Help 1.9 tdi 90 boost pressure sensor
    By chris_90 in forum Vento - 1994 - 1998
    Last Post: 20-04-2014, 10:53 PM
  2. 00575 boost pressure control failure - how I fixed it.
    By ed_crouch in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 24-09-2011, 02:33 PM
  3. Boost pressure Sensor
    By Frankiebaby in forum Golf MK5 - 2004 - 2009
    Last Post: 10-09-2009, 12:11 AM
  4. Audi S4 Boost Pressure Sensor
    By wadi110 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-10-2008, 10:09 PM
  5. Boost Pressure Sensor - need help with wiring
    By turbobugger in forum Beetle 2000-
    Last Post: 17-04-2008, 06:26 AM
