Thread: Vent Selection wrong
  1. Question Vent Selection wrong
    Aug 2014
    Newport, S Wales
    When selecting which vents for the heater, i.e. directing to defrost or body or feet vents. The selection doesnt match what I am getting. I can get air out of all the vents but it is wrong.
    Basically the selector doesn't match where the air is flowing.
    The dash has been removed and new fitted due to airbag deployment, pretty sure its related to this, I just don't know how the selector works. After a bit of info before diving in??
  2. Re: Vent Selection wrong
    vespa Guest
    Quote Originally Posted by ian.milling View Post
    If the airbag was done for YOU then take it back to the garage who id it and tell them to fix it FOC
  3. Re: Vent Selection wrong
    Aug 2014
    Newport, S Wales
    had the dash off today working on the airbag module (had it coded to car) so whilst it was off i had a look. The selector works by turning the valve direct via a spring like cable, this must be in the wrong position, unfortunately i didnt pay attention and didnt know where the air was blowing when i switched it off, so now i cant set it to the correct position! doh!!
    Know how to sort it though! just need time!
  1. selection of available accessories
    By Ben in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 12-10-2009, 11:58 AM
  2. Help with tyre selection
    By 8ball in forum Wheels and Tyres
    Last Post: 19-03-2009, 10:38 PM
  3. First Gear Selection
    By Greenfield in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 17-12-2008, 06:24 PM
  4. Gear Selection
    By fencer in forum Golf MK3 - 1993 - 1999
    Last Post: 04-06-2008, 06:49 PM
