Thread: Rough idle 1.2 azq 3 cylinder
Results 11 to 20 of 27
  1. Re: Rough idle 1.2 azq 3 cylinder
    Aug 2014
    Not to hand at the minute but I'll post them on here tomorrow. I just can't understand it because I've changed just about everything that could be at fault really and getting close to giving up
  2. Re: Rough idle 1.2 azq 3 cylinder
    Aug 2014
    Am I correct in thinking the angle sensors are on the pedal and throttle body crasher?
  3. Re: Rough idle 1.2 azq 3 cylinder
    1840 Post(s)
    The one that is showing the error you have is the throttle body, both the pedal and throttle body have dual opposite swing potentiometers. I had this fault on a Lupo 1 litre a few years ago and it was the ECU. It is rare for an ECU to fail but it does happen. One of the fault codes you posted on the other thread is very specifically and unambiguously a faulty ECU.
  4. Re: Rough idle 1.2 azq 3 cylinder
    Aug 2014
    I've tried a different ecu and it was still showing the same symptoms. I'm thinking the wiring has got to be at fault
  5. Re: Rough idle 1.2 azq 3 cylinder
    Aug 2014
    I've also changed the pedal Ms throttle body
  6. Re: Rough idle 1.2 azq 3 cylinder
    1840 Post(s)
    Did you run it with the new ECU after coding it in and adapting it to the immobiliser with it then showing the same fault codes?
  7. Re: Rough idle 1.2 azq 3 cylinder
    #17
    Aug 2014
    Yeah still got the same problem. I changed the ecu, ignition chip so the ecu so it would recognise it and the clocks so I wouldn't have to recode the ecu. It did come up with the ecu fault before and after the ecu change but that fault has now gone (original ecu is back on so the mileage was correct). I plug the vcds back in and get the codes on here for you to have a browse and see what you think. I can't think what it can be because like I said I've changed just about everything. It only happens once it's up to temperature 90'c. Could it be that the chain is attached and when the car is up to temperature the chain is stretching causing the fault? Unlikely I know but I can't think of anything else
  8. Re: Rough idle 1.2 azq 3 cylinder
    #18
    1840 Post(s)
    You could do with checking the valve timing.
  9. Re: Rough idle 1.2 azq 3 cylinder
    #19
    Aug 2014
    Is there measuring block on vcds to check or is it a case of rocker cover off?
  10. Re: Rough idle 1.2 azq 3 cylinder
    #20
    Aug 2014
    This comes up when starting from coldImageUploadedByTapatalk1411038007.479314.jpg
  1. Rough Idle
    By tosh123 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 19-03-2013, 03:52 PM
  2. Question Rough idle
    By PCDoctor in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-08-2010, 08:40 AM
  3. Please Help Very Rough Idle
    By kasper1287 in forum Golf MK4 - 1999 - 2004
    Last Post: 06-03-2010, 05:34 PM
  4. Rough idle
    By grahall in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-11-2009, 08:23 PM
  5. Question A4 2.6 rough idle/rough at high rpm
    By teccyjim in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 13-09-2008, 07:22 PM
